10 - NGC - Servo Motors and Axis Cables
Next Gen Control Electrical - Service Manual
  • 1 - NGC - Introduction
  • 2 - NGC - Activation
  • 3 - NGC - Software Update
  • 4 - NGC - Firmware Update
  • 5 - NGC - Configuration
  • 6 - NGC - Error Report and Backup
  • 7 - NGC - Main Processor
  • 8 - NGC - I/O and TC PCB
  • 9 - NGC - CAN Systems and Autodoor
  • 10 - NGC - Servo Motors and Axis Cables
  • 11 - NGC - 4th and 5th Axis
  • 12 - NGC - Servo Amplifiers
  • 13 - NGC - Vector Drive
  • 14 - NGC - Regen
  • 15 - NGC - 320V Power Supply
  • 16 - NGC - Wye / Delta
  • 17 - NGC - Circuit Breaker and Transformer
  • 18 - NGC - PSUP PCB
  • 19 - NGC - SKBIF and LCD Monitor
  • 20 - NGC - Remote Jog Handle
  • 21 - NGC - 115V LED - WorkLights
  • 22 - NGC - CabCool
  • 23 - NGC - MyHaas
  • 24 - NGC - Networking
  • 25 - NGC - 8M PCB
  • 26 - NGC - Robot and Automation
  • 27 - NGC - Machine Data Collection
  • 28 - NGC - Control Icons
  • 29 - NGC - Sensors and Switches
  • 30 - NGC - USB
  • 31 - NGC - Keypad
  • 32 - NGC - Broken Tool Detection
  • 33 - NGC - IPFDM PCB
  • 34. NGC - LVPS
  • 36 - NGC - High Intensity Lights
  • 10.1 Axis Assignments
  • 10.2 Positions View - Axis Selection
  • 10.3 Axis Grid Offset
  • 10.4 Axis Servo Motor and Axis Cables - Troubleshooting
Axis Assignments - NGC
RD0003
Revision A - 01/2026
Axis Assignments
The axis parameters on machines with the Next Generation Control are designated in groups. The number that precedes the period designates the axis. The number that follows the period is the parameter group number. The following table shows the axis assignments for the axes on a mill or lathe.
Motion Axis NGC Axis Label Axis Parameter Group Physical Input/Output Connector Mill or Lathe Specific
X X 1.xxx 1 Mill/Lathe
X(2) GM X(Slave) 1.xxx 8 Mill
Y Y 2.xxx 2 Mill/Lathe
Z Z 3.xxx 3 Mill/Lathe
Main Spindle S 4.xxx 6 Mill/Lathe
Secondary Spindle SS 12.xxx 14 Lathe
A A 5.xxx 4 Mill
Tool Turret TT 9.xxx 7 Lathe
B B 6.xxx 5 Mill
Hydraulic Tailstock B 6.xxx 9 Lathe
Servo Tailstock B 6.xxx 5 Lathe
C C 7.xxx 5 Mill/Lathe
Servo Tool Carousel TT 9.xxx 14 Mill
Servo Tool Changer Arm TA 11.xxx 7 Mill
Live Tool LT 10.xxx 11 Lathe
Barfeeder BF 13.xxx 10 Lathe
Servo Pallet Changer PC 14.xxx - Mill
Pallet Pool Rotate PR 15.xxx 15 Mill
Pallet Pool Slide PS 16.xxx 16 Mill
Compact Auto Part Loader / Auto Part Loader "U" Axis AU 17.xxx 13 Mill/Lathe
Compact Auto Part Loader / Auto Part Loader "V" Axis AV 18.xxx 15 Mill/Lathe
Auto Part Loader "W" Axis AW 19.xxx 16 Mill/Lathe
Slave  - 20.xx - Mill
Electric Vise 1 EV1 21.xx - Mill
Electric Vise 2 EV2 22.xx - Mill
Axis Parameters
The following screenshot shows the grid offset parameter group. The group number for grid offset parameters is 140 and the number that precedes it is the axis designation. For example, parameter 1.140, is the grid offset parameter for the X Axis.
Axis Alarms
The axis alarms for machines with the Next Generation Control are similar to parameter groups. They are similar to parameter groups in that one alarm group number is used for all of the axes. The axis at fault is designated by the number before the period. The alarm group number is the number after the period.
You must troubleshoot all of the axis alarms as you would the same alarm on a machine with the Classic Haas Control (CHC).
The following table compares some Servo Overload alarms on a Classic Haas Control machine with the same alarm on a Next Generation Control machine. All of the other axis alarms follow the same structure.
 Note: CHC Alarms 109, 110, 111, 188, 271, 674, along with other Servo Overload alarms, will not appear on a NGC machine. They are all replaced by Alarm group number 108 and are differentiated by the axis designation number that precedes the period.
CHC Servo Overload Alarms NGC Servo Overload Alarms
Alarm 108 - X SERVO OVERLOAD Alarm 1.108 - X AXIS SERVO OVERLOAD
Alarm 109 - Y SERVO OVERLOAD Alarm 2.108 - Y AXIS SERVO OVERLOAD
Alarm 110 - Z SERVO OVERLOAD Alarm 3.108 - Z AXIS SERVO OVERLOAD
Alarm 111 - A SERVO OVERLOAD Alarm 5.108 - A AXIS SERVO OVERLOAD
Alarm 188 - B SERVO OVERLOAD Alarm 6.108 - B AXIS SERVO OVERLOAD
Alarm 271 - C SERVO OVERLOAD Alarm 7.108 - C AXIS SERVO OVERLOAD
Alarm 674 - TT SERVO OVERLOAD Alarm 11.108 - TA AXIS SERVO OVERLOAD
10.2 Position View - Axis Selection
Position View - Axis Selection - NGC
This procedure tells you how to change the axes that show in the Positions box. The Positions box displays a maximum of 5 axes.
Push [POSITION].
Push [ALTER].
Select the axes you want to view in the Positions box.
You must de-select an axis if there are more than the maximum of 5 axes.
For this procedure we will remove the C axis and add the T axis.
Navigate to the C axis [1].
Push [ENTER] to remove the mark from the box.
The C axis goes away from the Positions box.
Navigate to the T axis [2].
Push [ENTER] to mark the box.
The T axis appears in the Positions box [3].
Push [ALTER] to close.
Axis Grid Offset - NGC
Applies to machines built from July 2015
Rotary Axis Grid Offset
Note: This section only applies to setting the Grid offset for stand alone rotaries. For setting grid offsets for other axis refer to the next section.
Warning: Only set a grid offset if ALARM 165 AXIS ZERO RETURN MARGIN IS TOO SMALL is generated when zero returning a rotary axis. If you have a dual axis rotary this only needs to be done for the axis that generates the alarm.
If you zero return a rotary axis and get ALARM 165 AXIS ZERO RETURN MARGIN IS TOO SMALL. Go to Setting -> Rotary then highlight the axis that generated the alarm. Select Set Offsets [1] by pressing [ALTER]. Press 2 [2] to select Set Grid Offset to set the grid offset.
Tool Changer Offset
Note: If you get ALARM 165 AXIS ZERO RETURN MARGIN IS TOO SMALL when zero returning an axis you must first set a grid offset before a tool changer offset can be set. See step 1.
The Tool Changer offset sets the location where a rotary will go during a tool change or after it zero returns.
Move the axis to the location you want the tool change offset to be during a tool change or after a zero return. Then go to Setting -> Rotary then highlight the axis you want to set the offset for. Then select Set Offsets [1] by pressing [ALTER]. Press 1 [3] to select Set TC Offset to set the tool change offset.
If grid or tool changer offsets have been made they can be saved for future use or transferred to a different machine.
Press F2 [1] then you will be prompted to name the new rotary file. This text will appear in the name column of the rotary table.
The file can be found in list program -> User data -> My Rotary. New files will have the name ROT_[name you gave the file]_[default rotary file name].
Axis Grid Offset With Service Key
Put the machine in Service mode.
Push [ZERO RETURN].
Push [ALL].
Push [DIAGNOSTIC].
Navigate to the Parameters tab.
Navigate to the Factory tab.
Type GRID and then press F1.
  • This shows all parameters that have the word "GRID" in the parameter name.
Type the axis letter you are setting (for example, 'X'), and then press F4 to set the grid offset for X.
If you need to set other grid offsets, repeat Step 1 but enter the corresponding axis letter.
This changes the Grid Offset parameters. For example, the letters X, Y, and Z set these Parameters:
  • 1.140 X_AXIS GRID OFFSET
  • 2.140 Y_AXIS GRID OFFSET
  • 3.140 Z_AXIS GRID OFFSET
  • 5.140 A_AXIS GRID OFFSET
  • 6.140 B_AXIS GRID OFFSET
  • 7.140 C_AXIS GRID OFFSET
For the T-Axis Grid Offset refer to Next Generation Control - Servo-Driven SMTC - Grid Offset and Tool Changer Offset.
For Lathe, TT-axis Offsets refer to TL-1/2 TT4 Tool Changer Offsets NGC
10.4 Axis Servo Motor and Cables - Troubleshooting Guide
Axis Servo Motor and Cables - Troubleshooting Guide - NGC
TG0033
Revision A - 07/2026
Download and fillout the Servo Motor Inspection Report Checklist below before replacing any parts.
Electrical Safety
 DANGER: Working with the electrical services required for CNC machines is extremely hazardous and can result in serious injury or death.
Before connecting line wires to the CNC:
  • Turn off all power to the machine at the source.
  • Perform a Lockout-Tagout (LOTO) procedure to ensure the power remains off during service.
  • Verify that power has been disconnected by using an AC voltage detector on all incoming lines.
If you are uncertain about how to safely disconnect power or perform LOTO procedures:
  • Do not proceed.
  • Contact qualified personnel or obtain appropriate assistance before continuing.
Failure to follow these precautions may result in electrical shock, equipment damage, or fatal injury.
 Danger: Before beginning any work inside the control cabinet, verify that the High Voltage indicator light on the 320V Power Supply / Vector Drive has been off for a minimum of five (5) minutes. This waiting period ensures that residual voltage has dissipated and reduces the risk of electric shock.
Certain service procedures involve high-risk electrical components and may pose serious injury or fatality hazards. Technicians must not attempt any procedure unless they have a complete understanding of the steps involved and the associated risks.
If there is any uncertainty regarding a procedure, contact your Haas Factory Outlet (HFO) to arrange for a qualified service technician.
Symptom Probable Cause Corrective Action
Alarm 1.9918, 2.9918 or 3.9918 X , Y or Z AXIS SERIAL ENCODER INTERNAL DATA ERROR
Alarm 1.9922, 2.9922 or 3.9922 X, Y or Z AXIS MOTION CHANNEL FAULT DETECTED
Alarm 1.9923, 2.9923 or 3.9923 X, Y or Z AXIS SOFTWARE DETECTED ENCODER FAULT
Alarm 1.9930, 2.9930 or 3.9930 X, Y or Z AXIS SERIAL ENCODER POOR COMMUNICATION
Alarm 1.9959, 2.9959 or 3.9959 X, Y or Z AXIS SERIAL ENCODER DISCONNECT
Alarm 1.9948, 2.9948 or 3.9948  X, Y or Z  AXIS SECONDARY ENCODER SERIAL FAULT
Alarm 1.9949, 2.9949 or 3.9949 X, Y or Z AXIS SOFTWARE DETECTED SECONDARY ENCODER FAULT
Alarm 1.9950, 2.9950 or 3.9950  X, Y or Z AXIS SOFTWARE DETECTED SECONDARY ENCODER FAULT
Alarm 1.9951, 2.9951 or 3.9951  X, Y or Z AXIS SECONDARY ENCODER SERIAL COMMUNICATION FAULT
Alarm 1.9960, 2.9960 or 3.9960  X, Y or Z AXIS SECONDARY SERIAL ENCODER CABLE FAULT
The  machine software is outdated.
Alarm is obsolete
New alarm for encoder faults updated in software. Update to latest version 100.21.000.1130 or Higher;
Added Alarms 9719 and 9720 for Encoder Fault Detection on Mocon Primary and Secondary Axes.
Alarm 1.9719, 2.9719 or 3.9719 X, Y or Z AXIS PRIMARY ENCODER SERIAL FAULT
Alarm Subcode (0x1) Encoder Data Fault  = (Alarm 9918 SERIAL ENCODER INTERNAL DATA ERROR)
Encoder signals are affected by noise from high power cables.
Faulty servo motor encoder.
Refer to Serial Data Communication Faults / Electrical Noise section below.
Check the servo motor for coolant intrusion. For VMC machines, new servo motor cables can be ordered to mitigate coolant intrusion. See HBC-N 03-13-25.
Alarm Subcode (0x2) Encoder Internal Axis Fault 1 = (Alarm 9922 MOTION CHANNEL FAULT DETECTED)
(The motion channel has reported an internal fault of a type that is not recognized by the control)
 Cycle power to the machine. If the issue persists, take an error report (Shift F3) and email to Haas Service
Alarm Subcode (0x3) Encoder Internal Axis Fault 2 =  (Alarm 9923 SOFTWARE DETECTED ENCODER FAULT)
 (Software has reported an internal fault of a type that is not recognized by the control.)
Alarm Subcode (0x4) Encoder CRC Fault =  (Alarm 9930 SERIAL ENCODER POOR COMMUNICATION)
 (Encoder signals are affected by noise from high power cables.)
 (Refer to Serial Data Communication Faults / Electrical Noise section below.)
Alarm Subcode (0x5) Encoder Cable Fault =  (Alarm 9959 SERIAL ENCODER DISCONNECT)
 (Cables are not connected correctly or encoder is faulty.)  (Inspect the cables and connectors. Refer to the Main Processor/Encoder Cable section below.)
Alarm 1.9720, 2.9720 or 3.9720 X, Y or Z AXIS PRIMARY ENCODER SERIAL FAULT
Alarm Subcode (0x1) Encoder Data Fault  = (Alarm 9948 SECONDARY ENCODER INTERNAL DATA ERROR)
Scale signals are affected by noise from high power cables.
(Faulty Linear Scale, Configuration File issue; incorrect motor type or incorrect Scale type.)
(Check Scale Encoder for coolant contamination.)
Alarm Subcode (0x2) Encoder Internal Axis Fault 1 = (Alarm 9949 SOFTWARE DETECTED SECONDARY ENCODER FAULT)
(The motion channel has reported an internal fault of a type that is not recognized by the control)  Cycle power to the machine. If the issue persists, take an error report (Shift F3) and email Haas Service
Alarm Subcode (0x3) Encoder Internal Axis Fault 2 =  (Alarm 9950 SOFTWARE DETECTED SECONDARY ENCODER FAULT)
Alarm Subcode (0x4) Encoder CRC Fault =  (Alarm 9951   SECONDARY ENCODER SERIAL COMMUNICATION FAULT )
(Liner Scale signals are affected by noise from high power cables.) (Refer to Serial Data Communication Faults / Electrical Noise section below.)
Alarm Subcode (0x5) Encoder Cable Fault =  (Alarm 9960 SECONDARY SERIAL ENCODER CABLE FAULT )
(Cables are not connected correctly or Linear scale is faulty.) (Inspect the cables and connectors. Refer to the Main Processor/Encoder Cable section below.)
Alarms 1.161, 2.161, 3.161 X, Y or Z AXIS DRIVE FAULT
Faulty servo amplifier. Check the corresponding amplifier assembly.
Refer to Servo Amplifier - Troubleshooting Guide to troubleshoot the amplifier.
Alarm 1.217, 2.217, 3.217  X, Y or Z AXIS PHASING ERROR Cables are not connected correctly  Inspect the cables and connectors. Refer to the Main Processor/Encoder Cable section below.
The wrong type of motor has been installed. Check that the correct motor type has been installed.  (Sigma-5 or Sigma-7)
Alarm 1.645, 2.645, 3.645 X, Y or Z AXIS AMPLIFIER GROUND FAULT Faulty power cable. Inspect the cables and connectors. Refer to Power Cable section below.
Faulty servo motor. Check the corresponding servo motor. Refer to Servo Motor section below.
Alarm 1.993, 2.993, 3.993 X, Y or Z AXIS SHORT CIRCUIT Faulty power cable. Inspect the cables and connectors. Refer to Power Cable section below.
Alarm 1.103, 2.103, 3.103 X, Y or Z AXIS SERVO ERROR TOO LARGE
Alarm 1.9920, 2.9920, 3.9920 X, Y or Z POSITION ERROR TOO LARGE
Encoder signals are affected by noise from high power cables. Or Faulty encoder. Refer to Serial Data Communication Faults / Electrical Noise section below. Check the encoder steps/revolution versus and ball screw pitch and verify the encoder counts are accurate per each rotation.
The axis motor brake, is not disengaging when servos are enabled. See the Motor Brake section below:
The axis ballscrew is damaged. Check the corresponding axis ballscrew.
Refer to Ballscrew - Troubleshooting Guide to troubleshoot the ballscrew.
Misaligned ballscrew coupling due to a crash
Verify that the ballscrew motor coupling is aligned refer to the Ballscrew - Troubleshooting Guide for further information on how to re-align the coupler
NOTE: Verify that the power cable is not faulty prior to attemping to align the motor coupling.
Alarm 103 AXIS SERVO ERROR TOO LARGE, during the zero return process. The axis zero returns in the wrong direction. The home sensor is being made during the zero return process causing the axis to zero return in the opposite direction. Check the axis home switch to make sure there are no metal chips on top of the sensor.
Alarm 552 TRIPPED CIRCUIT BREAKER (on UMC-1000) Damaged wire conduit and wires within conduit. Remove back panel. Inspect wire conduit. If damaged, contact Haas Service Department for assistance.
The machine servos make a humming noise while sitting idle, jogging, or on a rapid. The axis grid offset needs to be adjusted. Perform the Axis Grid Offset adjustment procedure.
The ballscrew is not aligned. Verify that the ballscrew does not bind during travel and that it is correctly aligned.
Outdated parameters. Download the latest configuration files. If the axis servo continues to hum, contact your local HFO for more troubleshooting information.
Alarm 9804 240 VAC GROUND FAULT gets generated when I zero return an Axis.
There is a short circuit on the cable or motor. Check for a short circuit on the corresponding servo motor and cable. Watch the Servo Power Cable and Motor Inspection Videos.
Note: If an alarm is generated on an ST machine when the A-axis is zero, return the LT axis cable, and check the motor for a short circuit.
AND/OR
Alarm 993 SHORT CIRCUIT
AND/OR
There may be a coolant intrusion on the axis servo motor.
Inspect the motor for coolant intrusion.  For VMC machines, new servo motor cables can be ordered to mitigate coolant intrusion. See HBC-N 03-13-25.
If the motor is replaced due to coolant intrusion, make sure to order the axis servo motor mount cover for the motor mount that is compatible with the motor.
Refer to the VF/VR - X/Y Motor Mount Cover - Reference document to verify motor mounts and their covers. This document wil also have the part numbers for ordering.
Any of the following alarms are generated after replacing the Mitsubishi Servo Motor with a Yasakawa Servo motor on the axis that had its motion sensor replaced.
1.9959  X AXIS SERIAL ENCODER CABLE FAULT
2.9959  Y AXIS SERIAL ENCODER CABLE FAULT
3.9959  Z AXIS SERIAL ENCODER CABLE FAULT
Patches to add parameters and tunes for the Yaskawa motor were not loaded.  Load configurations to apply the patches. Configuration File - Download/Load - NGC.
Any of the following alarms are generated after replacing the Mitsubishi Servo Motor with a Yasakawa Servo motor on axes that did not have their servo motor replaced and still have a Mitsubishi Servo.
1.9719 X AXIS SERIAL ENCODER FAULT
2.9719 Y AXIS SERIAL ENCODER FAULT
3.9719 Z AXIS SERIAL ENCODER FAULT
Sub code 0x4 or 0x5.
Extra Mitsubishi to Yaskawa conversion patches were not replaced.
Delete the unnecessary patches. Review AD0656 VMC - X/Y - Axis Servo Motor - Replacement or AD0556 VMC - Z-Axis - Servo Motor - Replacement. For additional information on replacing linear axis servo motors, see RD0100 How To Delete a Patch File for additional information about removing patch files.
Sigma-5 servo motors, non-contact encoders output serial data signal to the control. If the serial data signal is missing or becomes unreliable the control will generate a serial data communication error. Electrical noise can cause the serial data signal from the encoder to become unreliable and cause false alarms. Follow the troubleshooting guide below to help eliminate the noise in the system.
  1. Incorrect machine grounding. Make sure the ground wire size is correct. Also the ground wire should run all the way back to the electrical panel.
  2. Noise from other equipment. Make sure the machine does not share it's electrical service with another machine.
  3. Loose encoder data connectors at PCB or at the motor encoder, can cause the serial data to become unreliable. Refer to the Main Processor / Encoder Cable section.
  4. Loose ground or high voltage power connectors will induce noise into the system.
    • electrical cabinet check for loose connection at all the ground and high voltage power terminals (vector drive, wye-delta contactors, transformer..etc).
    • pendant check for loose terminal connectors.
    • spindle head check for loose ground and motor power terminals.
  5. The ferrite filters suppress high frequency noise produced by the amplifiers and vector drive, when servos are on. Make sure they are installed in:
    • Encoder data cables. Make sure there is a ferrite filter P/N 64 1252 installed in all the encoder data cables.
    • Axis motor power cables. Make sure there is a ferrite filter P/N 64-1252 installed in X, Y, Z axis motor power cables [1].
    • Spindle motor cables. Make sure there is a ferrite filter installed in the motor output of the vector drive.
      For a 40HP vector with 6 wire leads [1] use ferrite P/N 64-1254.
      For a 40HP vector with 3 wire leads [2] use ferrite P/N 64-1252.
      For a 20HP vector drive with 6 or 3 wire leads [3, 4] use ferrite P/N 64-1252.
  6. Cable routing. Make sure that the encoder cable is separated from high power spindle/axis/pump cables.
Maincon PCB / Encoder Cable
Corrective Action:
Examine the connector [1] on the Maincon. Make sure it is not damaged.
Examine the cable. Look for signs of damage or stiffness. The connector [4] has two housings [2,3] for the cable pins.
If the pins have been pushed into the motor, you must replace the motor and cable together.
Make sure the cable is firmly connected at both ends. Reseat both connections. Make sure the cable is installed in the correct connector at the Maincon or MOCON PCB.
Power Cable
Inspect the connector at the motor, look for loose connections between motor to cable or between cable spade terminals to amplifier. Check for connector contamination.
NOTE: Gently tug on the cables when checking for loose connection on the amplifier side. Pulling on the cables with excessive force can damage them.
Look for signs of damage and stiffness on the cable and connector. Disconnect the power cable from the amplifier and motor. Measure the resistance from leg to leg (red, white, black wires), and from leg to ground (green/yellow wire). Make sure the measurements result in an open connection. Refer to the table below as a reference.
NOTE: If the machine is experiencing intermittent short circuit alarms move the axis to the location where the cable would be most bent before performing this test. This may improve the likeliness of finding an intermittent  short.
Servo Power Cable Wiring Reference Table
Function Color  Motor End Amplifiier End
Phase A Red A Spade
Phase B White B Spade
Phase C Black C Spade
Chassis Ground Green/Yellow D Ring
Braid Braid Not Connected
Perform a continuity test between the ground wire and the braided shield. If it fails the continuity test fails the cable shield is compromised.
Check each leg from one end of the cable to the corresponding leg on the other end of the cable for continuity. Refer to the table above for wiring reference. If there is an open connection, there is a problem with the cable.
Use the following troubleshooting chart to determine whether the motor, amp, or cable is defective.
When Alarm 993 SHORT CIRCUIT occurs disconnect the axis power cable from the motor. Press [RESET] and jog the axis.
If Alarm 103 AXIS SERVO ERROR TOO LARGE occurs then the motor is defective. If another Alarm 993 SHORT CIRCUIT occurs then the cable or amp is defective.
To determine if the cable or amp is defective disconnect the axis power cable from the motor and amp. Press [RESET] and jog the axis.
If Alarm 993 SHORT CIRCUIT generates then the amplifier is defective. If Alarm 103 AXIS SERVO ERROR TOO LARGE generates the cable is defective.
Servo Motor
Corrective Action:
Disconnect and inspect the power cable at the motor side. Verify the motor connectors are not contaminated, coolant contamination can generate drive fault alarms and damage the amplifier. Verify that the cable is connected to the corresponding amplifier as well.
Measure the resistance from the pins Labeled A, B, and C at the motor connector to the chassis ground.
  • The reading must show an open circuit
  • If the reading does not show an open circuit, the motor is at fault
Conduct a continuity test from the ground pin and chassis ground. The multimeter should beep or read less than 1 ohm resistance for continuity, otherwise then there is a short in the motor. Measure the resistance between the pins labeled A, B and C, refer to the table below for the resistance values.
NOTE: Nominal winding resistance has been added to the table for the 4-wire test method, when using a multimeter use the typical resistance value column for the expected values.
DC-1 30 Taper - Tool Carousel Motor without Brake
Important: Machines built before 3/1/2025 will have the motor without the brake.
The DC-1 tool carousel motor is a sigma7 size 04 motor. The pinout for the phases looks different than other axis motors.
This image shows the pins on the motor connector:
  1. Gnd
  2. Phase A
  3. Phase B
  4. Phase C
NOTE: The Gnd pin [1] should be longer than the other pins as shown in the image.
Motor type
Haas PN
MPN
Motor size
Nominal winding resistance (Ohms)
Typical DMM measured winding resistance (Ohms)
Sigma 5
62-10011/ 62-10010
SGMGV-09ADA-HA11/ SGMGV-09ADA-HA21
0.894
0.9
62-10013/ 62-10012
SGMGV-13ADA-HA11/ SGMGV-13ADA-HA21
13
0.554
0.6
62-10015/ 62-10014
SGMGV-20ADA-HA11/ SGMGV-20ADA-HA21
20
0.291
0.4
62-0101/ 62-10027
SGMSV-30ADV-YA11/ SGMSV-30ADA2E
30
0.179
0.3
Sigma 7
62-0127B
SGM7A-02AFK-HA21
6.6
62-4445 SGM7A-04A7D61 4 4.3 4.2
62-0117/ 62-0124
SGM7G-09AFA-HA11/ SGM7G-09AFA-HA21 9 0.882 1.0
62-0119/ 62-0118
SGM7G-13AFA-HA11/ SGM7G-13AFA-HA21
13
0.557
0.6
62-0120/ 62-0123
SGM7G-20AFA-HA11/ SGM7G-20AFA-HA21
20
0.286
0.4
62-0122/ 62-0121
SGM7G-30AFB-HA11/ SGM7G-30AFB-HA21
30
0.177
0.2
Mitsubishi J5
62-0138/ 62-0141
HK-ST102WK-S101212/ HK-ST102WBK-S101212
1.254
1.4
62-0137/ 62-0140
HK-ST172WK-S101212/ HK-ST172WBK-S101212
13
0.807
0.9
62-0142/ 62-0139
HK-ST202AWK-S101212/ HK-ST202AWBK-S101212
20
0.558
0.7
Mitsubishi J3
62-0087/ 62-0088
HF-SP81MK-S12/ HF-SP81MBK-S12
1.149
1.4
62-0089/ 62-0095
HF-SP131MK-S12/ HF-SP131MBK-S12
13
0.692
0.8
62-0096/ 62-0097
HF-SP181MK-S12/ HF-SP181MBK-S12
20
0.456
0.5
Delta
62-0108/ 62-0109
ECMC-FW1308RS/ ECMC-FW1308SS
0.737
 0.8
Motor Brake
Corrective Action:
Reseat the the connection for connectors P3, P4, or P5 on the I/O PCB.
Measure the voltage across the red and black cables.
Press [EMERGENCY STOP]. There should be no voltage.
Press [RESET] to clear the alarms. The voltage should be between 20-30 VDC.
Examine the connection at the motor's brake [2] and power connectors [3] for contamination. Reseat the connections.
If no voltage is present, refer to:
  • Next Generation Control - I/O PCB -Troubleshooting Guide
Electrical Diagrams
