16 - NGC - Wye / Delta
Next Gen Control Electrical - Service Manual
  • 1 - NGC - Introduction
  • 2 - NGC - Activation
  • 3 - NGC - Software Update
  • 4 - NGC - Firmware Update
  • 5 - NGC - Configuration
  • 6 - NGC - Error Report and Backup
  • 7 - NGC - Main Processor
  • 8 - NGC - I/O and TC PCB
  • 9 - NGC - CAN Systems and Autodoor
  • 10 - NGC - Servo Motors and Axis Cables
  • 11 - NGC - 4th and 5th Axis
  • 12 - NGC - Servo Amplifiers
  • 13 - NGC - Vector Drive
  • 14 - NGC - Regen
  • 15 - NGC - 320V Power Supply
  • 16 - NGC - Wye / Delta
  • 17 - NGC - Circuit Breaker and Transformer
  • 18 - NGC - PSUP PCB
  • 19 - NGC - SKBIF and LCD Monitor
  • 20 - NGC - Remote Jog Handle
  • 21 - NGC - 115V LED - WorkLights
  • 22 - NGC - CabCool
  • 23 - NGC - MyHaas
  • 24 - NGC - Networking
  • 25 - NGC - 8M PCB
  • 26 - NGC - Robot and Automation
  • 27 - NGC - Machine Data Collection
  • 28 - NGC - Control Icons
  • 29 - NGC - Sensors and Switches
  • 30 - NGC - USB
  • 31 - NGC - Keypad
  • 32 - NGC - Broken Tool Detection
  • 33 - NGC - IPFDM PCB
  • 34. NGC - LVPS
  • 36 - NGC - High Intensity Lights
  • 16.1 WYE / Delta Replacement
  • 16.2 Wye / Delta Troubleshooting
  • 16.3 ABB Wye/Delta - N.O. AUX Contacts
16.1 Wye-Delta Contactor - Replacement
AD0328
This procedure tells you how to replace the Wye-Delta (Y/D) contactor assembly on a machine with a Classic Haas Control (CHC) or a Next Generation Control (NGC).
NGC control Mills built before 8/2017 the following is required for the first time the Wye-Delta assembly is replaced.
  • Mill software version 100.17.000.2034 or higher
  • I/O PCB firmware version 2.05, 2.07 or higher. DO NOT USE version 2.06
  • NGC I/O PCB: 34-3480A and 34-3480B, are not compatible with latest Wye-Delta assembly it must be replaced with a newer version.
  • Wye-Delta contactor patch file.
     Note: The patch gets added automatically to the configuration files after the Wye-Delta assembly order gets processed. If not email: [email protected] to have the patch added to the machine configuration files on the portal.
Electrical Safety
 DANGER: Working with the electrical services required for CNC machines is extremely hazardous and can result in serious injury or death.
Before connecting line wires to the CNC:
  • Turn off all power to the machine at the source.
  • Perform a Lockout-Tagout (LOTO) procedure to ensure the power remains off during service.
  • Verify that power has been disconnected by using an AC voltage detector on all incoming lines.
If you are uncertain about how to safely disconnect power or perform LOTO procedures:
  • Do not proceed.
  • Contact qualified personnel or obtain appropriate assistance before continuing.
Failure to follow these precautions may result in electrical shock, equipment damage, or fatal injury.
 Danger: Before beginning any work inside the control cabinet, verify that the High Voltage indicator light on the 320V Power Supply / Vector Drive has been off for a minimum of five (5) minutes. This waiting period ensures that residual voltage has dissipated and reduces the risk of electric shock.
Certain service procedures involve high-risk electrical components and may pose serious injury or fatality hazards. Technicians must not attempt any procedure unless they have a complete understanding of the steps involved and the associated risks.
If there is any uncertainty regarding a procedure, contact your Haas Factory Outlet (HFO) to arrange for a qualified service technician.
Removal
Locate the Wye-Delta contactor assembly.
Classic Haas Control:
Mills:
  • The Wye-Delta contactor assembly is in the electrical cabinet.
Lathes:
  • ST series: The Wye-Delta contactor assembly is located in the electrical cabinet.
  • DS-30: The main spindle Wye-Delta contactor assembly is located in the electrical cabinet.  The sub-spindle Wye-Delta contactor assembly is located behind the sub-spindle motor.
  • SL series: The Wye-Delta assembly is located underneath the Hydraulic Power Unit (HPU).
Next Generation Control:
Mills:
Lathes:
  • ST series: the Wye-Delta contactor assembly is located in the electrical cabinet.
  • DS-30: The main spindle Wye-Delta contactor assembly is located on the side of the main spindle motor.  The sub-spindle Wye-Delta contactor assembly is located in the electrical cabinet.
Remove the cover plate.
Mark the cable connections that do not have a label.
Remove the installed Wye-Delta contactor assembly.
Classic Haas Control - Installation
Mills and Lathes:
Install the new Wye-Delta contactor assembly. Connect the vector drive and spindle motor cables to the Y/D assembly as shown in the illustration.
 Note: In some machines a white color wire was used instead of blue.
Machines with PRE- I/O S PCB connect cables to I/O PCB at P12 and P58.
Machines with POST- I/O S PCB connect cable to I/O PCB at P53A.
Cablepart number 33-1068/1071 [2] is not used on a machine with a Classic Haas Control, tuck this cable into the cable track.
 Important: Make sure all the wires are connected to the correct terminals and that the screws are tightened.
Vector Drive - WYE/DELTA - NGC- Installation
Mills and Lathes:
Connect cable 33-1076A/1077A to I/O PCB at P37.
Connect cable part number 33-1068/1071 to I/O PCB at P63 and P64.
Servo Amplifier - WYE/DELTA - NGC - Installation
Mills and Lathes:
Test
Test the operation of the Wye‑Delta contactor assembly:
  • Run the spindle at different speeds.
  • Orient the spindle. If the spindle oscillates during orientation check for loose wires.
Next Generation Control: If the machine experiences Alarms: 9101.013, 9101.014 or 9973 please instruct the customer to submit an error log report ([Shift] + [F3]) immediately after the alarm to [email protected] for analysis.
16.2 Wye - Delta Contactor - Troubleshooting Guide
Wye - Delta Contactor - Troubleshooting Guide - NGC
TG0165
Revision A - 03/2026
Wye / Delta - Troubleshooting Videos
Components
  1.  Wye contactor.
  2. Delta contactor.
  3. 120 VAC Power cable.
  4. Wye/Delta Feedback cable (NGC machines only)
Electrical Safety
  • Do not proceed.
Symptom table
SYMPTOM POSSIBLE CAUSE CORRECTIVE ACTION
Alarm 2041 VECTOR DRIVE OR SPINDLE AMPLIFIER-OVERLOAD, and/or the spindle load pegs to 200% when any spindle speed is commanded. There is an open coil on one of the Wye-Delta contactors. Check the Wye-Delta connections for arching or burn marks. Make sure the connections are tight.
There is no voltage from the I/O PCB to the Wye contactor coil. Measure the resistance and the voltage.  Refer to Wye Contactor Voltage Inspection section.
The encoder belt is damaged, or the Non-Contact Encoder has a fault Inspect the encoder belt, encoder connections, encoder gaps and encoder alignment.
Alarm 123 SPINDLE DRIVE FAULT at any spindle speed, and Alarm 2040 VECTOR DRIVE OR SPINDLE AMPLIFIER-SHORT CIRCUIT. Faulty Wye-Delta contactor assembly. Check the Wye-Delta connections for arching or burn marks. Make sure the connections are tight.
Faulty vector drive. Inspect the vector drive and look for a shorted output.
Go to: Vector Drive - Troubleshooting Guide to troubleshoot the vector drive.
Alarm 4.9973 INVALID POWER CONTROL STATE DETECTED after software update. The WYE/DELTA feeback cables are not connected or not connected correctly. See the NGC-WYE-DELTA with Feedback Troubleshooting section below.
The WYE/DELTA patch is enabled and the WYE/DELTA contactors do not have a feeback cable.
Alarm 9973 or 4.9973 INVALID POWER CONTROL STATE DETECTED when the machine accelerates to maximum RPM. There is a problem with the incoming AC line power. Check the incoming AC line voltage.  Make sure you have all three phases from the top of the main circuit breaker to the main transformer.
The DELTA contactor is not engaging, or the WYE contactor is welded shut. See the NGC-WYE-DELTA with Feedback Troubleshooting section below.
AND
The machine has an ABB or Eaton brand assembly.
The config files are out of date. Load the updated config files. Reference the Configuration File - Download/Load - NGC procedure.
20008 Wye/Delta recovery triggered: S (SPINDLE) notification in the alarm history.
The control detected a possible problem with the WYE/DELTA contactors.
This message appears in the alarm history because the control detected the WYE/DELTA contactor feedback states to be incorrect but not long enough to generate alarm 4.9973.
  • Check all the WYE / DELTA terminal connections make sure they have a tight connection.
  • Check the transformer taps to be in the correct location.
  • Find out if these messages occur during heavy cuts.
Do not replace any parts, if these messages continue to occur generate an error report and email it to Haas Service.
Alarm 4.116  S(SPINDLE) SPINDLE ORIENTATION FAULT. There is a loose connection on the WYE/DELTA buss connectors. Inspect the WYE/DELTA contactor buss connections make sure they are making all the terminal leads.
Spindle load pegs to 200% There is an open coil on one of the Wye-Delta contactors. Check the Wye-Delta connections for arching or burn marks. Make sure the connections are tight.
New versions of the NGC-WYE-DELTA assemblies come with a feedback cable. This feedback cable allows the control to detect the current state of the WYE-DELTA contactors. If the control detects an invalid contactor state (i.e. both contactors engaged, or not engaged when commanded) the control will generate an alarm.
For alarm 9973 or 4.9973 INVALID POWER CONTROL STATE DETECTED check the following:
  1. Search the NGC software release notes on the Haas Portal for any updates regarding alarms 9973 or 4.9973.
  2. Determine if machine is equipped with the WYE-DELTA with feedback. Look at the NGC I/O PCB P63 and P64 connectors you should have cables going to these locations .
     Note: Machines built after 8/2017 will have the new version of contactors installed (no patch is required). If a WYE-DELTA contactor assembly (with feedback cables) was field installed, a software upgrade, I/O PCB firmware upgrade, and a patch is required to activate this feature. Refer to the Wye-Delta Contactor - Replacement procedure for more details.
  3. Make sure the contactor is switching correctly and the correct feedback is being detected.
    • Go to Diagnostics > I/O tab.
    • Type in keyword "Main" and press [F1] to search.
    • Select 154, 158 (INPUTS), 56, 57 (OUTPUTS) and press the [ALTER] button to filter the WYE/DELTA inputs and outputs.
    • Use the table below to determine if the contactor feedback is correct.
 Important: If the contactor logic state is not correct check the wiring going to each contactor, also check that is connected correctly at the I/O PCB (P63 DELTA, P64 WYE) (see drawing of the feedback cable below). If the wiring is correct make sure the contactors are not mechanically stuck.
NGC WYE-DELTA Feedback Logic Table
Contactor State Diagnostic Input Value Diagnostic Output Value
WYE contactor = ENABLED
DELTA contactor = DISABLED
(154) Main_Spindle_WYE_Input 0 (57) Main_Spindle_WYE 1
(158) Main_Spindle_Delta_Input 1 (56) Main_Spindle_Delta 0
WYE contactor = DISABLED
DELTA contactor = ENABLED
(154) Main_Spindle_WYE_Input 1 (57) Main_Spindle_WYE 0
(158) Main_Spindle_Delta_Input 0 (56) Main_Spindle_Delta 1
Wye-Delta Assembly Inspection
Corrective Action:
Inspect the Wye-Delta assembly. Make sure that all connections are tight, and that there are no signs of arching or burn marks on the contactors, burnt marks on the jumper bus-bar or contacts.
With the machine OFF, measure the resistance across the coil between connectors A1 and A2. The resistance should read 10-100 Ohms. If the reading is open (OL) or less than 5 ohms, then the coil is defective.
Note: If the resistance measured is less than 5 ohms, then the short at the coil may have caused damage to the I/O PCB. Inspect the I/O PCB by following the I/O PCB - Troubleshooting Guide - NGC.
Power-up the machine and make sure that only the Wye contactor is energized when no spindle speed is commanded. If both contactors are closed at the same time, one of the contactors may be stuck (welded shut). The vector drive sees this condition as a short.
Corrective Action:
  1. Power up the machine and wait until the machine finishes booting up.
  2. Measure the voltage across the coil between the A1 and A2 connectors of the Wye contactor. It should read 120 VAC.
    • If the voltage is correct, but the contactor does not engage, the contactor may have a mechanical issue.
    • If there is no voltage present, the problem may be caused by the I/O PCB, or the wiring from the Wye/Delta to the I/o PCB
    •  Go to:
      • Next Generation Control - I/O PCB - Troubleshooting Guide
Delta Contactor Voltage Inspection
Corrective Action:
  1. Power-up the machine and enter a program in MDI that commands the spindle to spin at 2000 rpm. Slowly increase the spindle speed while observing the diagnostics page.
  2. Output (56) Main_Spindle_Delta.  At the moment this bit changes from 0 to 1, the Delta contactor is energized.
  3. Measure the voltage across the Delta contactor’s coil between the A1 and A2 connectors.
    • Go To:
Electrical Diagrams
Vector Drive - Wye-Delta System - Interconnect Diagram
Vector Drive - Wye-Delta System with Contactor Feedback Interconnect Diagram - Reference Only
Servo Amplifier - Wye-Delta System - Interconnect Diagram
16.3 ABB Wye/Delta - N.O. AUX Contacts - Installation
AD0571
This procedure outlines how to install ABB Normally Open (N.O.) AUX contacts to the ABB Wye/Delta assembly.
This procedure applies to the following service kits:
  • 93-3418: ABB Y/D N.O. CONTACTS SERVICE KIT
Move the N.C. AUX contacts to the center position of each contactor (see red boxed contacts in image). To remove the N.C. AUX contacts press up the latch [1] and slide the N.C. AUX contacts forward.
Remove the red [2] and red/white [3] wires on cable 33-1071 from the internal N.O. contact in the Delta contactor.
Note: For assembly 32-5282C, the red [2] and red/white [3] wires are from cable 33-1068.
Remove the black [4] and black/white [5] wires from the internal N.O. contact in the Wye contactor.
Install the N.O. AUX contacts from the kit onto the right most position of each contactor (see red boxed contacts in image).
Connect the red [1] and red/white [2] wires from cable 33-1071 to the N.O. AUX contact as shown.
Connect the black [3] and black/white [4] wires to the N.O. AUX contact as shown.
Note: Torque the N.O. AUX contact screws to 1 Nm.
Verification
 Handle jog the spindle back and forth until the WYE and DELTA contactors change states.
Warning: If you have a lathe, make sure to remove any parts from the workholding before jogging the spindle.
If alarms are generated, check the connections.
