14 - NGC - Regen
Next Gen Control Electrical - Service Manual
  • 1 - NGC - Introduction
  • 2 - NGC - Activation
  • 3 - NGC - Software Update
  • 4 - NGC - Firmware Update
  • 5 - NGC - Configuration
  • 6 - NGC - Error Report and Backup
  • 7 - NGC - Main Processor
  • 8 - NGC - I/O and TC PCB
  • 9 - NGC - CAN Systems and Autodoor
  • 10 - NGC - Servo Motors and Axis Cables
  • 11 - NGC - 4th and 5th Axis
  • 12 - NGC - Servo Amplifiers
  • 13 - NGC - Vector Drive
  • 14 - NGC - Regen
  • 15 - NGC - 320V Power Supply
  • 16 - NGC - Wye / Delta
  • 17 - NGC - Circuit Breaker and Transformer
  • 18 - NGC - PSUP PCB
  • 19 - NGC - SKBIF and LCD Monitor
  • 20 - NGC - Remote Jog Handle
  • 21 - NGC - 115V LED - WorkLights
  • 22 - NGC - CabCool
  • 23 - NGC - MyHaas
  • 24 - NGC - Networking
  • 25 - NGC - 8M PCB
  • 26 - NGC - Robot and Automation
  • 27 - NGC - Machine Data Collection
  • 28 - NGC - Control Icons
  • 29 - NGC - Sensors and Switches
  • 30 - NGC - USB
  • 31 - NGC - Keypad
  • 32 - NGC - Broken Tool Detection
  • 33 - NGC - IPFDM PCB
  • 34. NGC - LVPS
  • 36 - NGC - High Intensity Lights
  • 14.1 Regen - Replacement
  • 14.2 Regen - Troubleshooting
14.1 Regen Assembly - Replacement
AD0279
Kit Part Number Description
93-32-0041B REGEN, 11 OHM 2 COIL RESISTORS
93-32-0043A REGEN, 7.5 OHM 3 COIL RESISTORS
93-32-5017 REGEN, 22 OHM (OM-1A/2A)
93-1038F REGEN, 6 OHMS 6 CERAMIC RESISTORS
93-1042G REGEN, 8.6 OHMS 6 CERAMIC RESISTORS
93-32-0042A REGEN, 5.6 OHM 4 COIL RESISTORS
93-32-0194 REGEN, 5.6 OHM (60HP VECTOR DRIVE)
93-1030 REGEN, 20 OHMS 3 CERAMIC RESISTORS
93-1040 REGEN, 15 OHMS 5 CERAMIC RESISTORS
Push [POWER OFF].
Set the main circuit breaker to the OFF position.
 Danger: If the voltage indicator light is on, do not touch the electrical components. The high voltage in the electrical cabinet can kill you. Wait for the voltage indicator LED to go off fully.
Disconnect the regen cable [1] from terminals 1 and 2 on the vector/spindle drive. If the regen assembly has ceramic resistors, disconnect the fan and thermostat cables.
 Note: Not all regen assemblies have a fan.
Remove the used regen assembly that has coil resistors [2], or that has ceramic resistors [3], from the top of the electrical cabinet.
Put the grommet [2] on the cable for the replacement regen assembly [1] through the hole at the top of the electrical cabinet.
Install the regen assembly.
Connect the cable to terminals 1 and 2 [3] on the vector/spindle drive. If the regen assembly has ceramic resistors, make these connections:
Fan cable to 92-91 on TB1 on the servo-distribution PCB
830 Oveheat cable to:
  • P20 Pre I/O-S PCB
  • P14 Post I/O-S PCB
Route the cable through the cable carrier.
 Note: Not all regen assemblies have a overheat cable.
920 Servo Regen cable on P10 on the Servo Distribuition PCB.
Note:  Not all regen assemblies have a servo regen cable.
14.2 REGEN - Troubleshooting Guide
TG0116
The REGEN load is the component responsible for dissipating the energy generated during deceleration. The REGEN converts the high energy load into heat with the use of resistors.
REGEN load assemblies currently used in machines:
Part Number Description Nominal Resistance (Ohms) Machine
93-32-5017 REGEN Assembly OM 22 OM
93-32-0041B REGEN Assembly Mini Mill 11 MM, TM, TL
93-32-0043A REGEN Assembly 7.5 Machines with a 20 HP Vector Drive
93-32-0042A REGEN Assembly 5.6 Machines with a 40 HP Vector Drive
93-32-0194 REGEN Assembly 55HP 5.6 Machines with a 60 HP Vector Drive
Alarm 123 SPINDLE DRIVE FAULT
Alarm 119 OVERVOLTAGE
Alarm 292 HIGH VOLTAGE POWER SUPPLY FAULT
Alarm 650 DC BUS OVERVOLTAGE
Alarm 444 REGEN REMAINED ON TOO LONG
Alarm 237 SPINDLE FOLLOWING ERROR
Alarm 647 REGEN LOAD SHORTED
The REGEN load is open or has a short circuit. Measure the REGEN resistors.
The Vector drive is defective. Chek the REGEN circuit at the vector drive.
The REGEN elements glow red/overheat when the machine is idle and is in [EMERGENCY STOP]
or Alarm 444 REGEN REMAINED ON TOO LONG
There is a problem with the incoming AC power. Measure the incoming AC Power.
The REGEN elements glow red/overheat when the machine is idle, and the servos are enabled. The symptom disappears when the [EMERGENCY STOP] is pressed,
There is a short on any of the servo motors and/or spindle motor. Measure the resistance to the servo motors and the spindle motor.
Lathes: The REGEN elements glow red/overheat when the machine runs constant surface speed G96 or when the spindle decelerates after a new chuck or part was installed. The deceleration/acceleration cycles are too aggressive. Review and reduce the spindle speed of acceleration/deceleration cycles.
Regen Inspection
Corrective Action:
Disconnect the REGEN load leads from the vector drive at terminals 1 and 2. Measure the resistance across the leads. The reading must be as follows:
  • 2-resistor box: between 9.5 and 12.5 ohms.
  • 3-resistor box: between 6.3 and 8.3 ohms ohms. (As shown in the illustration.)
  • 4-resistor box: between 4.6 and 6.6 ohms.
Measure each lead to the ground to make sure the REGEN does not have a short circuit.
Note: A reading in the range of Megaohms from leg to chassis is not an indication of a shorted unit.
If the REGEN loads are within specification, there can be a problem with the vector drive refer to: Vector Drive - Troubleshooting Guide to troubleshoot the vector drive.
Short Circuit Inspection
Corrective Action:
Check the REGEN circuit at the vector drive.
Go to to: Vector Drive - Troubleshooting Guide to troubleshoot the vector drive.
Incoming AC Voltage Inspection
Corrective Action:
Measure the incoming voltage to the machine at the main incoming breaker in the control. Make sure that the incoming voltage is within the range of the transformer’s tap [1]. Move the lines to the correct tap if needed.
Servo and Spindle Motor
Corrective Action:
Check each one of the servo motors and spindle motor. Measure the resistance from each one of the motor cables to chassis. Make sure that each one of the wires measures open to chassis. With the machine power off, disconnect all of the cables from each one of the amplifiers and measure the resistance of each terminal to the amplifier enclosure. Each terminal must measure open to the amplifier enclosure.
Review the Part Program
Corrective Action:
Make sure the deceleration/acceleration cycles are not too aggressive during G96 Constant Surface Speed cycles.
Add short dwell times between passes.
Electrical Diagram
