    3. Español
    13. Русский
Search
      • Drill/ Tap/ Mill Series
      • Robot Packages
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
      • 5% off + saving on Automation
      • VF-2SS
      • 05-0258
      • 08-1760
      • 08-1760
      • 08-1761
      • video-test-page
      Mill Toolholding Mill Workholding Manual Chucks For Milling Milling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Broaching Tool Management Tooling Accessories Deburring & Abrasives Package Kits Apparel & Accessories Storage & Handling Measuring & Inspection Winner's Circle
      • Drill Chucks
      • Pull Studs
      • Mill Toolholding Kits
      • Fixed Jaw Vises
      • Mill Vise Jaws
      • Workholding Accessories
    • Milling
      Milling Shop All
      • Burrs
      • Cut-Off Tooling
      • Grooving Tools
      • Small ID Grooving & Threading Tools
      • Threading Toolholders
      • Boring Bars
      • OD Toolholders
      • Haas Notch Groove & Thread Inserts
      • Haas Notch Groove & Thread Toolholders
      • TL & CL Toolholding
      • BOT Toolholding
      • BMT Toolholding
      • Live Toolholding
      • Reduction Sleeves
      • VDI Toolholding
      • Spindle Liners
      • Lathe Collet Chucks
      • Lathe Boring Rings
      • ER Collets
      • Straight Shank Keyless Drill Chucks
      • Broaching Toolholders
    • Tool Management
      Tool Management Shop All
      • Spindle Taper Cleaner
      • CNC Clearing Fans
      • Lathe Tooling Kits
    • Storage & Handling
      Storage & Handling Shop All
      • Test Bars
      • Inspection Kits
      • Tool Setting Measuring Gauges
      FINANCING & OPEN TERMS FINANCING & OPEN TERMS
    3. Español
    13. Русский
Search
Automatic Rotary Parameter - Installation - CHC
Service Home How To Procedures Automatic Rotary Parameter - Installation
Recently Updated Last updated: 04/16/2019
- Jump to Section - 1. Introduction 2. Tools Required 3. Automatic Rotary Parameter Installation (5 steps) Back to Top
This procedure tells you how to install the correct rotary parameter file for all CNC mills with a software version higher than 18.08A. It updates the ROTARY.RPK file, which changes the default rotary parameters that are used when a new rotary is selected in the Haas Software.
If you have a software version lower than 18.07A, use the Parameter Checker to get the correct rotary parameters.
Tools Required
  • USB memory drive the ROTARY.RPK loaded in the root drive.
Press [EMERGENCY STOP].
Turn Settings 30 and 78 to OFF.
 Note: The control will prompt you to save the currently selected rotary parameters. Press WRITE/ENTER to continue.
Press [LIST PROG] and navigate to the HARD DRIVE tab.
 Note: If the HARD DRIVE tab is not shown, temporarily enable it on by turning on Parameter 737:10, ENABLE HARD DRIVE.
Go into the USERS folder.
Go into the ROTARY folder.
Delete all the rotary files in the folder.
Insert the USB drive into the CNC machine.
Go into DEBUG mode.
Press [LIST PROG] and navigate to the USB drive.
Press [F1].
Select Load Rotary and press [WRITE/ENTER].
Press [POWER OFF].
Press [POWER ON]. Test rotary operation.
Turn Settings 30 and 78 to NEW to select the desired rotary product.
Cycle the Power.
Test the operation of the rotary.
 Note: If you turned Parameter 737:10 ENABLE HARD DRIVE, ON in Step 2, make sure to turn it OFF.
FIND DISTRIBUTOR
  • Twitter
© 2023 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
