  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      Why Haas MyHaas Education Community Industry 4.0 Haas Certification Customer Testimonials
  • Service
  • Videos
      Haas Tooling Mill Toolholding Mill Workholding Milling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Tool Management Tooling Accessories Package Kits Measuring & Inspection Apparel & Accessories
      HAAS TOOLING QUICK LINKS
      NEW PRODUCTS NEW PRODUCTS
      OPEN TERMS OPEN TERMS
      FINANCING FINANCING
      Haas Service Parts Automatic Pallet Changer Automatic Tool Changer Chip Management Coolant Counterbalance Electrical Cabinet Enclosure Field Install Options Hydraulics Lubrication Maintenance Pendant Probing Rotary Spindle Tailstock
My Cart
Find A Dealer
    3. Español
    13. Русский
Search
EC-400 Rotary Belt Replacement
Service Home How To Procedures EC-400 Rotary Belt Replacement
Recently Updated Last updated: 10/17/2018
- Jump to Section - 1. Belt Replacement (2 steps) Back to Top
Belt Replacement
Remove the rotary motor covers.
Loosen the set screw in the motor spacer [1]. Remove all (4) motor bolts [2].
Push the motor towards the rotary body and tilt it back to remove the belt [3].
Install the new belt over the rotary pulley. Tilt the motor back as you put the belt over the flang on the motor pulley. Install the motor bolts hand tight. Tighten the set screw in the motor spacer [1] to set the belt tension. Torque the motor bolts to 30 ft lbs.
Re-install the rotary motor covers.
Zero return the B Axis, set the Grid Offset (press B + F4 while on the parameter page in service mode.)
Handle jog the rotary until the arrow on the pallet is pointing towards the spindle.
Mount a mag base with indicator on the spindle. Jog the X Axis and indicate the face of the pallet. Handle jog the rotary until the face is parallel to X Axis is within 0.002".
While on the parameter page in service mode, press B + F2 to set the TC Offset.
Command a pallet change to verify that the B and Z axis TC Offsets are set correctly.
FIND DISTRIBUTOR
  • Twitter
© 2022 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
