Main Control PCB - (Plug-in Type) - Battery Replacement - NGC - AD0285
Service Home How To Procedures Main Control PCB - (Plug-in Type) - Battery Replacement - NGC - AD0285
Recently Updated Last updated: 06/07/2022
AD0285
Applies to machines built from May 2015, till June 2016
- Jump to Section - 1. Introduction 2. Electrical Safety 3. Battery Test 4. Battery Replacement Back to Top
This procedure shows you how to replace the plug-in battery on a NGC Main Processor.
Parts Required
  • CR15270 with Connector Lithium-Ion battery
Electrical Safety
 Caution: When you do maintenance or repair on CNC machines and their components, you must always follow basic safety precautions. This decreases the risk of injury and mechanical damage.
  • Set the main circuit breaker to the [OFF] position.
 Danger: Before beginning any work inside the control cabinet the High Voltage indicator light on the 320V Power Supply / Vector Drive must have been off for at least 5 minutes.
Some service procedures can be dangerous or life-threatening. DO NOT attempt a procedure that you do not fully understand. If you have any doubts about doing a procedure contact your Haas Factory Outlet (HFO) and schedule a service visit.
Battery Test
Measure the voltage of the battery on the Main Control PCB (Printed Circuit Board).
Use a digital multimeter.
If the voltage is less than 3.0 VDC (Volts Direct Current), replace the battery.
Battery Replacement
Connect the lead from the LITH BATT W/CONN [A] to the open connector at J1 or J17 on the Main Control PCB.
Cut the cable tie that holds the installed battery in place. Remove and discard the installed battery.
Use a cable tie[B] to attach the replacement battery to the PCB.
Set the machine date and time. Refer to the Next Generation Control - Date/Time Change procedure.
