Monitor - 10-Inch CRT - To LCD Replacement - AD0156
Service Home How To Procedures Monitor - 10-Inch CRT - To LCD Replacement - AD0156
Recently Updated Last updated: 01/31/2022
AD0156
Applies to machines built from: January, 1990 to January, 2003
- Jump to Section - 1. Introduction 2. Removal (1 step) 3. Installation (2 steps) Back to Top
This procedure tells you how to replace a 10-inch CRT monitor with an LCD monitor. This procedure applies to LCD monitors that either have and do not have a plastic bezel.
[A] 93-5222A QTY: 1 MONITOR, CRT TO LCD FOR MACHINES WITH CRT
Removal
Push [POWER OFF].
Remove the rear cover [1] of the pendant.
Remove the notepad bracket [2] and other brackets attached to the side of the pendant.
Disconnect the CRT power cable [4] and the data cable [3].
Remove the monitor [5].
Caution: Before you remove the last top nut, support the weight of the monitor.
Clean the inside of the protective glass.
For monitors that do not have a bezel:
  • Install the screws and the 1" standoffs [1] to the LCD MONITOR [A] and monitor housing.
For monitors that have a bezel:
  • Install the screws and the 3/8" standoffs [2] to the LCD MONITOR [A] and monitor housing.
  • Clean the included bezel glass [5].
  • Install the foam gasket [6], the bezel glass, and the masking mat [4] into the rear side of the bezel [7].
    Caution: During installation, hold the parts together to make sure parts do not fall.
  • Use the flat push nuts [3] to install the bezel assembly to the LCD MONITOR [A].
Remove the protective cover from the monitor.
Install the monitor. Install the top nuts first.
Connect the LCD power cable [9] and data cable [8].
Set the main circuit breaker to the ON position.
Push [POWER ON].
The LCD MONITOR [A] is pre-programmed for the best resolution. If the screen does not show an image, press [CURNT COMDS] on the keypad and press the [AUTO] button [1] at the upper rear of the monitor bracket [2]. This autotunes the data to the display settings. If some text is cut off at the edge of the screen on any page perform the autotune on that page.
Cycle the power. Install the cover [3] of the pendant.
Install the note pad bracket [4] and other brackets that attach to the side of the pendant.
