OM-1 / OM-2 - MPO Spindle - Lubrication Tube - Replacement - AD0123
Service Home How To Procedures OM-1 / OM-2 - MPO Spindle - Lubrication Tube - Replacement - AD0123
Recently Updated Last updated: 08/08/2023
AD0123
Applies to machines built from: April, 2014
- Jump to Section - 1. Introduction 2. Replacement (7 steps) Back to Top
This procedure tells you how to convert the Office Mill spindle lubrication tube from a 5/32" hose to a 1/4" hose. Do this when you install a mid-point oiling (MPO) spindle. The spindle includes the lubrication-tube conversion kit (P/N 93-2221) that contains the necessary hose and fittings used in this procedure.
Replacement
Disconnect the lubrication hose clamp [1].
Remove the hose clamp standoff [2].
Discard the clamp and the standoff.
Use alcohol to clean the end of the 5/32" tube.
Tape one end of the 1/4" tube to the end of the 5/32" tube.
Make sure you tape the (2) tubes tightly.
Remove the 5/32" spindle lubrication tube [1] from the lube injector assembly on the lubrication panel.
Pull the 5/32" tube [2] from the machine until the tape connection [3] to the 1/4" tube [4] comes into view.
Discard the 5/32" tube.
Install the1/4" fitting [1] provided in the kit into the lube injector assembly.
Connect the 1/4" spindle lubrication tube [2] to the fitting.
Remove the plug [1] from the MPO spindle lubrication port.
Install the 1/4" elbow fitting [2] provided in the kit into the spindle lubrication port.
Connect the 1/4" tube to the 1/4" elbow fitting.
Install the lube panel cover [1].
Install the spindle head cover [2].
