Spindle Encoder Jumper - Installation
Service Home How To Procedures Spindle Encoder Jumper - Installation
- Jump to Section - 1. Introduction 2. Installation (3 steps) Back to Top
Recently Updated Last updated: 05/13/2025
Revision B - 5/2025
Warning: When you are working on a machine with the spindle encoder disconnected it is necessary to jump the encoder cable. This tool will allow you to jog the axis on the machine without generating a spindle encoder alarm.
Warning: Do not run the spindle with the jumper tool installed.
A machine with the classic control requires a parameter change and a jumper. A machine with the NGC requires factory setting changes. Use this procedure to help you through the process.
Tools Required:
  • T-0142 Spindle Encoder Jumper
Power off the machine.
Classic Haas Control - disconnect the encoder cable [1] from P6 on the Maincon / Mocon PCB. Install the a spindle-encoder jumper [2] in its place.
Next Generation Control - disconnect the encoder cable [1] from P22 [Channel 6] on the NGC Main PCB. Install the a spindle-encoder jumper [2] in its place.
Power on the machine.
Note: Machines equipped with an optical or magnetic spindle encoder skip this step.
Machines with a non contact encoder:
Classic Haas Control set parameter 783 Spindle Encoder Type to 0.
Note: Record the original value of this parameter.
Note: Download the latest configuration files to make sure Factory Setting 4.116 SPINDLE ENCODER TYPE appears on the factory setting tab.
Change the following factory settings:
  • 4.116 Spindle Encoder Type from 4 to 0
  • 30.072 Spindle Uses Analog Thermal Sensor from 1 to 0
  • 4.004 Spindle Disabled from False to True
Important: Changing the parameters before installing the jumper will revert back to the original values when the power is cycled.
When finish with the repair.
Classic Haas Controls - Set 783 Spindle Encoder Type back to its original value if the value has changed.
Next Generation Controls -
  • Change factory settings back to their original value if the value has changed.
Power off the machine and remove the jumper.
Power the machine on and make sure no spindle encoder alarms are present.
