UMC - 500/750/1000/SS - Hennig CDF Conveyor Extension Panel - Replacement - AD0733
Service Home How To Procedures UMC - 500/750/1000/SS - Hennig CDF Conveyor Extension Panel - Replacement - AD0733
8.5 UMC - 500/750/1000/SS - Henning CDF Conveyor Extension Panel - Replacement
Recently Updated Last updated: 05/07/2024
AD0733
This procedure will explain how to install the Hennig CDF Conveyor Extension Panel replacement. The kits comes with a new Extension Panel to fix any coolant leaks in the following machines:
  • UMC-500
  • UMC-750
  • UMC-1000
UMC-500/SS built before 2/24/22:
  • 93-3613: CONV EXTENSION PANL KIT UMC-500 CDF
UMC-750/1000/SS built before 4/29/22:
  • 93-3612: CONV EXTENSION PANL KIT UMC-750/1000 CDF
Extension Panel Installation
Push [E-STOP].
Remove the gaskets [1] from the each side of the conveyor.
 NOTE: This will make installing the conveyor easier and to avoid damaging the gasket.
Remove the bolts from the adapter brackets to the extension panel.
Remove the conveyor brackets [1] from the enclosure.
 NOTE: These brackets may come in the color red. Some conveyors may not have these brackets. Remove brackets if it is screwed onto the enclosure and save them for later.
Use a big joe or a forklift, attach straps to the lifting hooks [1] and support the other end of the conveyor [2] to begin sliding the conveyor out half way.
Loosen the hex head bolts [1] that hold the casters in place.
Loosen them enough so that the rollers touch the floor but can freely move up and down.
Remove extension panel and install the new extension panel [1] provided in the kit to the conveyor and slide conveyor back in towards the casting.
NOTE: The extension panel does not bolt to the conveyor, it is wedged between the casting and conveyor.
With the conveyor pushed back in, bolt the conveyor brackets [1] back onto the enclosure.
 NOTE: These brackets may come in the color red. Some conveyors may not have these brackets installed. Only attach the brackets if they previously had them screwed onto the conveyor.
Bolt the extension panel of the conveyor to the adapter brackets as shown.
With the conveyor still supported by the lifting apparatus, tighten the hex head bolts [1]. Make sure the casters are touching the floor.
Verify the machine height for the coolant tank after the conveyor is completely installed.
 NOTE: Releveling may be required after conveyor is completely installed if the machine leveling needed to be adjusted to install the CDF conveyor.
Remove the lifting apparatus after the bolts are tightened.
Re-install the gasket [1] after the conveyor is fully installed.
 NOTE: It may be easier leaving the conveyor a few inches out to access the first couple screws to the gasket and then push the conveyor all the way in to install the remaining screws.
13
After completing the installation, remove the [E-STOP] and turn on the coolant and press [CHIP FWD] to run the Conveyor to check for any leaks.
