UMC - Mini Conveyor - Field Installation - AD0719
Service Home How To Procedures UMC - Mini Conveyor - Field Installation - AD0719
Recently Updated Last updated: 02/09/2024
AD0719
- Jump to Section - 1. Introduction 2. Installation (11 steps) 3. Mini Conveyor Operation (1 step) Back to Top
This procedure demonstrates how to install a Mini Conveyor on a UMC machine.
Machine Compatibility
You can install the Mini Conveyor on the following machines that have an external 55-gallon (208 L).
  • UMC - 500/SS
  • UMC - 750/SS
  • UMC - 1000/SS
  • UMC - 1500-DUO/SS
Machine requirements:
  • UMC-500/SS machines require kit 93-3921 or 93-3928 to be installed before adding a Mini Conveyor. Refer to UMC - 500/SS - SPILLWAY EXTENSION - REPLACEMENT before installing a Mini Conveyor.
  • UMC-750/1000/1500/SS machines require kit 93-3937 or 93-3938 to be installed before adding a Mini Conveyor. Refer to UMC - 750/1000/1500/SS - Spillway Extension - Replacement before installing a Mini Conveyor.
  • Machines will either need an angled chip hopper or will need to order 93-1001021 MINI CONV CHIP FUNNEL FIELD INSTALL UMC.
This procedure applies to the following kit:
  • 93-1001004 MINI CONVEYOR FIELD INSTALL KIT UMC
 You should not do mechanical or electrical machine repairs or service procedures unless you are qualified and knowledgeable about the processes.
 Only authorized personnel with the proper training and certification should do this repair procedure.
 All information herein is provided as a courtesy for Haas machine owners for reference and illustrative purposes only. Haas Automation cannot be held responsible for repairs you perform. Only those services and repairs that are provided by authorized Haas Factory Outlet distributors are guaranteed.
Use the dimensions specified in the illustration to mark the hole locations to install the Mini Conveyor Bracket in the next step.
  • [1] 2 x 0.219” (5.5626 mm) Diameter Hole
  • [2] 0.33” (8.382 mm)
  • [3] 12” (3.048 mm)
Use self-tapping screws to install Mini Conveyor Bracket.
Note: Mini Conveyors with no Tensioning Spring, add Spring provided in the kit following Step 3 and Step 4. If Tension Spring is already in place, skip to step 5.
Holding the Jam Nut [3] in place, unscrew Tensioning Screw [1] and insert Tensioning Spring [2] between both tension brackets and screw Tensioning Screw [1] back in as you hold the Jam Nut [3] in place. The Tensioning Screw should be going through the Tensioning Spring as pictured in step 8.
Add Tensioning Spring to both left and right side of the Mini Conveyor and evenly tension the belt.
Replace wings with new wings provided in kit. Use ¼ x 20 bolts to install Left Wing [1] and Right Wing [2].
 Note: Check the motor name plate. It should be a 1 RPM motor [1]. If a 5 RPM motor [2] is installed, it will need to be retrofitted to a 1 RPM motor. Refer to the Mini Conveyor - Motor Replacement.
Important: Machines without an angled chip hopper will need to install MINI CONV CHIP FUNNEL [1].
Use (4) FBHCS 1/4-20 X 1/2 SLF-TP to install the MINI CONV CHIP FUNNEL [1].
Place Mini Conveyor onto Coolant Tank.
Slide Coolant Tank in place.
With the Coolant Tank in place, position the Chip Bin under the conveyor discharge.
Use the Cable Ties and Magnetic Cable Holders as necessary to route the cable along the Coolant Tank.
Route cable using cable holder inside rear enclosure.
Connect the 115VAC Splitter Plug to the GFCI outlet located inside the control cabinet.
Route the Splitter down into the lower cabinet box and connect to the Mini Conveyor power plug. Some machine models may need to use Extension Cable provided with kit.
If the machine has a Haas Oil Skimmer installed. Unplug the 25 FT Extension Cable from the GFCI and plug it into one of the open outlets of the 115VAC Splitter.
Note: To reduce the wear on the belt, Mini Conveyor unit should be kept in the OFF position when not in use.
  • Turn the power switch to the ON position during high chip discharge operation.
  • Empty the Chip Bin when full.
