      • Tornio manuale
  3. Collari autocentranti ER per codoli diritti
  4. 04-1487
04-1487
04-1487
04-1487
04-1487
Collari autocentranti a codoli diritti ER25 3/4" | Passaggio refrigerante nel mandrino
N. pezzo: 04-1487
ST SHANK COLLET CHUCK 3/4" X ER25
Prezzo: 75.95 ( / unità)
This straight shank ER25 collet chuck accepts a variety of ER25 collet styles, and has a 0.75 in \ 3/4" shank. The precision cylindrical shank has one flat, and will mount into any internal (ID) turning holder with the appropriate bore size and set-screw clamping. The double-taper collet design provides high clamping force for round, smooth shank tools, and offers a wide gripping range with excellent TIR and balance. The collet chuck is through-tool coolant (TSC) capable, and also may be used as an extended-length milling collet, by clamping it into the appropriate end mill holder.
Serie collare ER-25
[ØBD] Diametro del corpo 1,65 pollici
[ØDMM] Diametro codolo 0,75 pollici\3/4"
[LS] Lunghezza codolo 2,95 pollici
[LSCX] Lunghezza di serraggio massima 4,1 pollici
[OAL] Lunghezza totale 4,8 pollici
[FS] Dimensione piatta 0,71 pollici
[TP1] Filettatura M12x1,0
Peso 1,1 lb \ 0,5 kg
Paese d'origine Cina
04-1487
04-1487
04-1487
04-1487
04-1487
04-1487
