      • Tornio manuale
  2. Serraggio dei pezzi fresatrice
  3. Vise Kits
  4. Kit montante e morsa autocentrante da 5"
Kit montante e morsa autocentrante da 5”
N. pezzo: 08-1168
5” Self Centering Vise and Riser Kit
Prezzo: 1699.95 ( / unità)
Prezzo: 36498.95 ( / unità)
Prezzo: 10862.95 ( / unità)
Prezzo: 1459.95 ( / unità)
Prezzo: 6569.95 ( / unità)
Prezzo: 15329.95 ( / unità)
1444.97
34675.00
10320.00
1386.97
6241.97
14564.00
Il montante Haas per morsa autocentrante da 5" è progettato per un montaggio su tutti i piatti ovali UMC Haas
* Tutta l’attrezzatura per il montaggio è inclusa nel montante.
Progettate per il montaggio sulle seguenti macchine universali Haas:
___________________________________
  • Modelli UMC-500/SS
  • Modelli UMC-750/SS
  • Modelli UMC-1000/SS
  • Modelli UMC-1250/SS
  • Modelli UMC-1000-P/SS
  • Modelli UMC-1500-DUO/SS
  3. Customer Photos
SETUPS MADE EASY
______________________________________________
BENEFITS:
This Mill Workholding Kit includes everything you need for basic workholding on a Haas UMC. It contains a self-centering vise, riser block, machinable vise jaws, and a part stop.
Our Haas 5" self-centering vise has a maximum opening of 5", and features a compact, low-profile design that automatically adjusts the workpiece to the center of the vise for increased precision and repeatability. The simple bolt-on jaws are easily changed or reversed, and have built-in serrated gripping surfaces which do NOT feature dovetail jaws. Includes one set of hardened-steel jaws, a ratchet wrench, and all necessary mounting hardware. Replacement hard jaws, as well as machinable steel and aluminum soft jaws, are available.
This riser block raises the vise 100mm off the platter surface to allow better access to all five sides of the workpiece during 5-axis applications. The sloped sides of the riser provide additional clearance for the spindle when the B-axis is at 90°. The riser is designed to mount to all Haas UMC platters, and all mounting hardware is included.
These aluminum and steel machinable vise jaws for Haas 5" self-centering vises are easily machined to the shape of your part for custom workholding applications. The flat/no step jaws are 5" wide by 2" tall by 2-1/2" thick.
Use the simple vise part stop to quickly locate your parts to the same position in your vise every time, reducing setup and changeover times when machining identical parts. No need for measurements or indicators, simply drop the part in the vise, slide it against the stop, tighten the vise – and you’re ready to machine.
This Kit Contains:
  • Haas Workholding 5" (130mm) Self-Centering Vise
  • Riser Block
  • Aluminum and Soft Steel Machinable Vise Jaws
  • Part Stop
Paese d'origine Taiwan
Tipo di morsa Autocentrante
Tipo Kit assortito
Tipo di morsa Manuale
Tipo di morsa Autocentranti
Numero di stazioni 1
[JW] Ampiezza ganascia 4,92 pollici\125,0 mm
[VO] Apertura morsa 5,0 pollici \ 130,0 mm
08-1168
