Troubleshooting Guide
Videos
How-To Procedure
CONTACT YOUR DISTRIBUTOR >A Haas Factory Outlet (HFO) can answer your questions, and walk you through your best options.
CONTACT YOUR DISTRIBUTOR >OVERVIEW
SERVICE DOCUMENTS
AVAILABLE ON THESE MACHINES
This heavy-duty steel chip conveyor has a built-in filtration system that allows coolant to pass through but not chips, reducing the accumulation of chips in the coolant tank. A series of wire brush scrapers self-cleans the filter box as the conveyor runs, removing any build-up of chips, and directing the chips up the conveyor chute.
The conveyor removes chips from the machine quickly, and discharges them at standard barrel height. The conveyor can be activated via M-code, or directly from the control pendant, and there are settings to control the interval and duration of the conveyor cycle for automatic operation. Smart-sensing technology automatically reverses the conveyor if a jam occurs.
NOTE: The Filter Conveyor is highly recommended for aluminum machining applications that generate large quantities of smaller chips.
ATTENTION: The Filter Conveyor ships with the machine, but does not fold like the standard conveyor, so it requires additional space to install and remove.
CAUTION: Do not part off solid pieces of material into the conveyor, as they could cause the conveyor to jam.
Videos
How-To Procedure
Toll Free: (888) 817-4446 / Fax: 805-278-8554
