Chip Conveyor - Motor - Replacement - AD0345
Service Home How To Procedures Chip Conveyor - Motor - Replacement - AD0345
8a.2 Chip Conveyor - Motor Replacement
Recently Updated Last updated: 05/14/2026
AD0345
This procedure tells you how to install and wire a replacement motor for a conveyor. When you receive the replacement motor, the cable for the motor will have one of these circumstances:
  • The cable may match your existing electrical cable. In this circumstance, no modification is necessary.
  • The cable may not match your existing electrical cable. In this circumstance, you have (2) options:
    • You can bypass the extension cable on the machine and connect the new motor cable directly to the I/O PCB.
    • You can take the cable off of the old motor and install it onto the new one. This procedure shows you how to make that modification.
Use P/N 93-1224C for Vertical Mills and Lathes.
Use P/N 93-2381 for Horizontal Mills.
For CDF conveyor motor replacements refer to AD0642 - CDF Chip Conveyor - Motor Replacement.
Conveyor Motor Brand Differences
Keyarrow Conveyors come with Michuen Motors [1] where the mount plate [2] is needed.
If the motor being replaced is a Bison Motor [3] on a Keyarrow Conveyor, the mount plate is NOT needed [4].
 NOTE: Do not dispose mount plate in case it is needed in the future.
Motor Replacement
Remove the cable clamps [1].
Remove the used motor.
Press the CHIPC MOTOR 1/8HP 235V 50/60HZ [A] onto the conveyor shaft. Align the slot in the motor shaft with the key [2] on the conveyor shaft.
Attach the motor to the conveyor head.
Install the cable clamps [1].
Connect the electrical cable.
NOTE: Vertical Mill and Lathe Machines that ordered 93-1224C that have a Jorgenson Conveyor will need to install CHIP CONV BRKT ADAPTER [1] and CHIP CONV BRKT ADAPTER SVC MTR COVER [2].
Do this step if you must modify the cable that came with the motor.
Cable Wire Connect to:
Blue Capacitor/motor black
Red Capacitor/motor brown
Black Motor gray
Green Ground
Yellow Cap off - no connection
Orange Cap off - no connection
White Cap off - no connection
Power on the machine.
Push [CHIP FWD].
If the motor is wired correctly, the chip conveyor moves forward.
Push [CHIP REV].
If the motor is wired correctly, the chip conveyor moves backward.
