      • Coating Thickness Gauges
      • Hardness Tester
      • Portable EDM
      • Rotary Workholding Kits
      • Parts Wash-Off Tools & Kits
Hennig CDF Conveyor - Installation - AD0551
Service Home How To Procedures Hennig CDF Conveyor - Installation - AD0551
8.4 Henning CDF Conveyor - Installation
Recently Updated Last updated: 05/07/2024
AD0551
This procedure will explain how to install the Hennig CDF Conveyor option found on the following machines:
  • UMC-500
  • UMC-750
  • UMC-1000
  • UMC-1250
  • UMC-1500-DUO
  • EC-400
  • EC-500
  • EC-630
  • 93-1000661: CHIP CONV UMC-500 CDF FIELD INSTALL
  • 93-1000655: CHIP CONV UMC-750 CDF FIELD INSTALL
  • 93-1000656: CHIP CONV UMC-1000 CDF FIELD INSTALL
  • 93-1000657: CHIP CONV UMC-1250 CDF FIELD INSTALL
  • 93-1000658: CHIP CONV UMC-1500 DUO CDF FIELD INSTALL
  • 93-1000659: CHIP CONV EC-400 CDF FIELD INSTALL
  • 93-1000660: CHIP CONV EC-500 CDF FIELD INSTALL
  • 93-1000950: CHIP CONV EC-630 CDF FIELD INSTALL
Prerequisites:
  • 93-1000573 I/O DOOR ASSY HINGED order the hinge door if it did not come in the kit.
  • EC-400 & EC 500 built BEFORE 2018 are NOT compatible with the CDF conveyors
  • All applicable machines must have a 95 gallon coolant tank
UMC - Installation
Place the conveyor in position, using a big joe or a forklift attach straps to the lifting hooks [1] and support the other end of the conveyor [2] to begin sliding the conveyor into the casting.
Remove the gaskets [1] from the each side of the conveyor. This will make installing the conveyor easier and to avoid damaging the gasket.
Loosen the hex head bolts [1] that hold the casters in place.
Loosen them enough so that the rollers touch the floor but can freely move up and down.
Begin to insert the conveyor into the machine, at the halfway point bolt the conveyor bracket [1] before completely sliding the conveyor in.
 NOTE: These brackets may come in the color red. Some conveyors either do not have these brackets or have them pre installed. Only attach if the bracket is not already screwed onto the conveyor.
Once the conveyor bracket is installed, install the extension panel [1] to the conveyor and continue sliding it in.
NOTE: The extension panel does not bolt to the conveyor, it is wedged between the casting and conveyor.
With the conveyor pushed in bolt the conveyor brackets [1] to the enclosure using the provided hardware.
Bolt the extension panel of the conveyor to the enclosure as shown.
With the conveyor still supported by the lifting apparatus tighten the hex head bolts [1]. Make sure the casters are touching the floor.
Remove the lifting apparatus after the bolts are tightened.
Re-install the gasket [1] after the conveyor is fully installed.
 NOTE: It may be easier leaving the conveyor a few inches out to access the first couple screws to the gasket and then push the conveyor all the way in to install the remaining screws.
Place the wash down pump into the coolant tank and connect the output of the pump to the valve on the conveyor.
Verify the machine height for the coolant tank after the conveyor is completely installed.
 NOTE: Releveling may be required after conveyor is completely installed if the machine leveling needed to be adjusted to install the CDF conveyor.
Once completed go to the Electrical Installation section of the procedure
EC - Installation
FOR EC-400/500 FIELD INSTALL
Remove the old panel and intall the new enclosure panel that will allow the CDF conveyor to fit on the EC machines.
FOR EC-630 FIELD INSTALL
NOTE: EC-630 machines will have two panels [1] & [2] instead of one panel to be installed for the CDF.
FOR FIELD INSTALL
Install the drain pan onto the machine, use the provided hardware in the hardware kit.
Remove the service panel [1] and the left drain pan cover [2] to prepare for installing the conveyor.
NOTE: Place the gasket for the service panel aside as you will need it later in the installation.
Place the conveyor in position, using a big joe or a forklift attach straps to the lifting hooks [1] and support the other end of the conveyor [2] to put the conveyor into the casting.
NOTE: Remove the chip disk filter cover [3] to make placing the conveyor into position easier.
Once the conveyor has been fully slid into the casting, reinstall the left drain pan cover [1] and the chip disk filter cover [2]. Lastly, reinstall the service panel [3] to the spillway. Make sure the gasket [4] is reinstalled as well to prevent leaks from occuring.
Place the wash down pump [1] into the coolant tank and connect the output of the pump to the valve on the conveyor.
Please install the hinge door and refer to the I/O PCB Hinged Door Installation procedure for further instructions.
Install the TMD card onto the hinge door located as shown in the picture using the spacers and the provided hardware [2].
NOTE: Older versions of the hinged door use 1/4-20 bolts, newer version hinged doors use 10-32 size bolts, both are supplied with the kit or pre-installed on the hinged door. Use the correct bolt size for the appropriate version of hinged door.
FOR UMC MACHINES:
Route the conveyor drive cable [1] and pump motor cable [2] using the provided cable clamps [3].
Route the cables along the skirt of the machine and into the back of the UMC into the junction box below the control cabinet.
FOR EC MACHINES:
Route the conveyor drive cable [1] and pump motor cable [2] into the rear of the control cabinet.
NOTE: Route the pump motor cable through the wire channel under the conveyor and spillway.
Follow the wiring diagram to wire the cables.
Connect 33-0987B from the transformer to the P4 on the TMD card.
NOTE: [1] There are some extensions provided for the transformer in case there is no more room to fit 33-0987B in the transformer.
Connect 33-0517 from P69 on the I/O board to P2 on the TMD card.
Connect 32-0971 from the junction box on the chip conveyor to P24 on the I/O board.
Connect 32-0972 from the pump motor to P1 on the TMD card.
After completing the installation, run the conveyor by pressing [CHIP FWD] if the conveyor runs backwards please check the motor wiring and verify it is wired correctly. Use the wiring diagrams below for reference.
