WiFi PCB Removal - AD0518
Service Home How To Procedures WiFi PCB Removal - AD0518
Recently Updated Last updated: 02/17/2021
WiFi - PCB - Removal
AD0518
This procedure outlines how to remove the WiFi component from the main PCB.
Note: Make sure to backup the machine before performing this task.
WiFi Removal
Follow these steps when performing this custom task on the COR600751.
Power OFF the machine.
Remove the main PCB cover.
Disconnect the WiFi radio frequency cable [1].
Disconnect the communication/power cable [2].
Remove the WiFi module [3] from the board. Squeeze the snap in plugs on the back side of the board and pull out the board from the top side.
Remove the Antenna Cable [4] from the PCB.
Remove the Antenna Cap [5] from the top of the control.
Remove the Antenna [6] from the top of the control.
Replace the Dome Plug C/W Hole [7] with the Dome Plug C/WO Hole on top of the control.
Put the main PCB cover back on.
Power on the machine and verify everything works correctly.
WiFi Removal - Desktop Mill
Follow these steps when performing this custom task on a Desktop Mill.
Tools Required: Micro phillips head screwdriver.
Remove the back panel, the WiFi module is notated at [1].
Remove the PCB at [2].
Remove the PCB with the WiFi module at [3].
Once the PCB containing the WiFi module is removed, unscrew the WiFi module from the back [1] and remove the WiFi module from the board.
Note: The main PCB should look like this when the WiFi module has been removed.
Reattach the removed PCBs.
Reattach the back cover.
Power ON the machine and ensure everything works correctly.
