APL Installation Kit, ST-20/Y–28/Y (20-25 INSTALL KIT)
Product Image
GET QUOTE
APL Installation Kit, ST-20/Y through ST-28/Y
    CNY ONLY
Everything you need to install your Haas APL
Images are for illustration only. Actual contents may vary.
  • Overview
  • Send Info
OVERVIEW
SERVICE DOCUMENTS
This required installation kit for Haas ST-20 through ST-28 lathes, including Y-axis models. Includes all the necessary items to install a Haas Automatic Parts Loader in your shop, so you can start making parts right away.
  • Door-open switch
  • Spring pusher for seating parts
  • Anchors for the APL
  • Drill guide for beam support on the lathe
  • Electrical: amplifiers, light curtain cables
  • Light curtain bracket
  • Beam support
  • Assorted hardware
SERVICE DOCUMENTS
Service Update
Intermittent Solenoid Related Alarms
Lathe APL - Bridge Shim
User Relays and Terminal Plug Connectors on NGC IO PCB - 34-3490B (Original Publish Date 02/27/2019)
Troubleshooting Guide
Automatic Parts Loader - APL - Troubleshooting Guide - NGC
How-To Procedure
APL Bar Stock Template - Installation - AD0478
APL Linear Rail Retrofit Kit - Installation - AD0471
APL V-Rail Retrofit Kit - Installation - AD0484
Haas Automatic Parts Loader (APL) - Fence Installation - AD0553
Haas Automatic Parts Loader (APL) - Lathe - Installation - AD0448
MCD Relay PCB - Replacement - AD0424
Instruction Manual
Haas Automatic Parts Loader Interactive Service Manual
Need More Information?
