What are G-Codes
Service Home What are G-Codes
Recently Updated Last updated: 03/22/2019
What are G-Codes?
What are G-Codes
- Jump to Section - 1. G-Codes Explained Back to Top
G-Codes Explained
About G-Codes
G-codes are used to command specific actions for the machine: such as simple machine moves or drilling functions. They also command more complex features which can involve optional live tooling and the C Axis.
Each G-code has a group number. Each group of codes contains commands for a specific subject. For example, Group 1 G-codes command point-to point moves of the machine axes, Group 7 are specific to the Cutter Compensation feature.
Each group has a dominant G-code; referred to as the default G-code. A default G-code means they are the one in each group the machine uses unless another G-code from the group is specified. For example programming an X, Z move like this, X-2. Z-4. will position the machine using G00.
 Note: Proper programming technique is to preface all moves with a G-code.
Default G-codes for each group are shown on the Current Commands screen under All Active Codes. If another G-code from the group is commanded (active), that G-code is displayed on the All Active Codes screen.
G-code commands are either modal or non-modal. A modal G-code stays in effect until the end of the program or until you command another G-code from the same group. A non-modal G-code affects only the line it is in; it does not affect the next program line. Group 00 codes are non-modal; the other groups are modal.
 Note: The Haas Intuitive Programming System (IPS) is a programming mode that either hides G-codes or completely bypasses the use of G-codes.
Group Number Definition
00 Non-modal
01 Motion
02 Plane Selection
03 Distance Mode
05 Feedrate Mode
06 Units
07 Cutter Compensation
08 Tool Length Offset
09 Canned Cycles
10 Return Mode in Canned Cycles
11 Scaling
12 Coordinate System Selection
15 Exact Stop
16 Rotation
23 Dynamic Work Offset
