  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      Why Haas MyHaas Education Community Industry 4.0 Haas Certification Customer Testimonials
  • Service
  • Videos
  • MyHaas – One Place for Everything
    • Compare Quotes
      • Compare Quotes
    • About MyHaas
      • About MyHaas
    • Haas CNC Certification Program
    • Haas Learning Resources
    • MyHaas App Form
      • MyHaas App Form
      Haas Tooling Mill Toolholding Mill Workholding Milling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Tool Management Tooling Accessories Package Kits Measuring & Inspection Apparel & Accessories
      HAAS TOOLING QUICK LINKS
      NEW PRODUCTS NEW PRODUCTS
      OPEN TERMS OPEN TERMS
      FINANCING FINANCING
      Haas Service Parts Automatic Pallet Changer Automatic Tool Changer Chip Management Coolant Counterbalance Electrical Cabinet Enclosure Field Install Options Hydraulics Lubrication Maintenance Pendant Probing Rotary Spindle Tailstock
My Cart
Find A Dealer
    4. Español - Méjico
    14. Русский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
15" LCD Cold Fire 2 to Maincon Upgrade - AD0476
Service Home How To Procedures 15" LCD Cold Fire 2 to Maincon Upgrade - AD0476
Recently Updated Last updated: 01/31/2022
AD0476
- Jump to Section - 1. Introduction 2. Electrical Safety 3. Remove Cold Fire 2 Components (2 steps) 4. Install Maincon Components (1 step) 5. Load the Software (1 step) Back to Top
This procedure will show you how to upgrade a 15" LCD CNC equipped with a CF-2 Processor PCB to a Maincon Processor PCB.  Do a machine backup before proceding with this procedure.
Compatibility:
  • Machine with a 15" LCD screen
  • Processor Cold Fire 2 with Mill 15.xx/16.xx or Lathe 8.xx/9.xx software version.
Important:  This procedure is to be peformed by a qualified service technician.
Refer to:
  • Machine Data Backup (Mill 15.xx and lower, and Lathe 8.xx and lower) - CHC
  • Machine Data Backup (Mill16.xx and higher, and Lathe 9.xx and higher) - CHC
Electrical Safety
 Caution: When you do maintenance or repair on CNC machines and their components, you must always follow basic safety precautions. This decreases the risk of injury and mechanical damage.
  • Set the main circuit breaker to the [OFF] position.
 Danger: Before beginning any work inside the control cabinet the High Voltage indicator light on the 320V Power Supply / Vector Drive must have been off for at least 5 minutes.
Some service procedures can be dangerous or life-threatening. DO NOT attempt a procedure that you do not fully understand. If you have any doubts about doing a procedure contact your Haas Factory Outlet (HFO) and schedule a service visit.
Open the control cabinet.
Remove the processor stack cover.
Disconnect the cables from the Mocon PCB.
Note:  Make sure you make all the cables before you disconnect them.
Remove the Mocon PCB.
Disconnect and Remove the ENET PCB (PC104) if equipped.
Remove the Cold Fire 2 PCB.
Remove the RS-232 PCB.
Remove the back pendant cover.
Disconnect the cables going to the SKBIF.
Remove the SKBIF PCB.
Remove the Beacon light.
Install the Maincon PCB.
Install Mocon2 PCB if equipped.
Install the SKBIF PCB.
Install the RS-232 PCB.
Install the LED Beacon Light.
Connect the wires acording to the Refer to the interconnect diagram shown below:
Load the Software
Perform the Maincon Control Software Load.  Refer to Maincon Control Software (Mill VER17 and Lathe VER10) - Load procedure.
FIND DISTRIBUTOR
  • Twitter
© 2022 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
