Find A Dealer
    4. Español - Méjico
    14. Русский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
      • Drill/ Tap/ Mill Series
      • Robot Packages
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
    • Product Image Automation
      Automation
      Automation View All
      • Automation
      • 5% off + saving on Automation
      • VF-2SS
      Mill Toolholding Mill Workholding Milling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Broaching Tool Management Tooling Accessories Package Kits Apparel & Accessories Storage & Handling Measuring & Inspection
      • Drill Chucks
      • Pull Studs
      • Mill Toolholding Kits
      • Fixed Jaw Vises
      • Mill Vise Jaws
      • Workholding Accessories
    • Milling
      Milling Shop All
      • Burrs
      • Cut-Off Tooling
      • Grooving Tools
      • Small ID Grooving & Threading Tools
      • Threading Toolholders
      • ID Toolholders
      • OD Toolholders
      • Haas Notch Groove and Thread Inserts
      • Haas Notch Groove and Thread Toolholders
      • TL & CL Toolholding
      • BOT Toolholding
      • BMT Toolholding
      • Live Toolholding
      • Reduction Sleeves
      • VDI Toolholding
      • Spindle Liners
      • Lathe Collet Chucks
      • Lathe Boring Rings
      • ER Collets
      • Straight Shank Keyless Drill Chucks
      • Broaching Toolholders
    • Tool Management
      Tool Management Shop All
      • Spindle Taper Cleaner
      • CNC Clearing Fans
    • Storage & Handling
      Storage & Handling Shop All
      • 7-Piece Measuring Kit
      • 3D Sensor Kit, Inch, CT40
      • 3D Sensor Kit, Metric, SK40/DIN
      • 3D Sensor Kit, Metric, BT40
      • 3D Sensor Kit, Inch, HSK63A
      • 3D Sensor Kit, Metric, HSK63A
      • 3D Sensor, Inch
      • 3D Sensor, Metric
      • WIPS Stylus, 3-Pack
      • WIPS Replacement Stylus
      • Spindle Test Bar
      • Coolant Refractometer
      • Clamp Force Gauge
      NEW PRODUCTS NEW PRODUCTS
      FINANCING & OPEN TERMS FINANCING & OPEN TERMS
Find A Dealer
    4. Español - Méjico
    14. Русский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
320V Power Supply Replacement - (93-32-5557B) - AD0422
Service Home How To Procedures 320V Power Supply Replacement - (93-32-5557B) - AD0422
Recently Updated Last updated: 01/31/2022
AD0422
- Jump to Section - 1. Introduction 2. Electrical Safety 3. Replacement / Installation - CHC 4. Replacement / Installation - NGC Back to Top
This procedure will show you how to replace 320V Power Supply on a Classic Haas Control and Next Generation Control.
This Document Applies to these Parts:
  • 93-32-5557B
Electrical Safety
 Caution: When you do maintenance or repair on CNC machines and their components, you must always follow basic safety precautions. This decreases the risk of injury and mechanical damage.
  • Set the main circuit breaker to the [OFF] position.
 Danger: Before beginning any work inside the control cabinet the High Voltage indicator light on the 320V Power Supply / Vector Drive must have been off for at least 5 minutes.
Some service procedures can be dangerous or life-threatening. DO NOT attempt a procedure that you do not fully understand. If you have any doubts about doing a procedure contact your Haas Factory Outlet (HFO) and schedule a service visit.
  1. [POWER OFF] the machine  and wait until the High Volt light is completely turned off.
  2. Mark and remove all the cables from the 320V Power supply.
    Note:  The new 320V Power Supply [1] does not need the +12VDC supply that was connected to J3 on the old power supply.
  3. Install the new 320V Power Supply [1].
  4. Connect the PS Fault cable to J4 [2].
  5. Connect the VMON cable to J2 [3].
    Note: Older machines did not have a VMON cable installed.  For these machines the VMON cable is not used.
  6. Connect the Regen cable [4] to the terminal strip.
    Note:  For machines that had the molex connectors use the Regen cable extension P/N 33-0470 that comes in the kit.
  7. Connect the 320VDC cable [5] to the terminal strip.
     Note:  For machines that had the molex connectors use the 320VDC cable  P/N 33-04902E that comes in the kit.
  8. Connect the 230VAC Input cable [6] to the terminal strip.
     Note:  For machines that had the molex connectors use the Power extension cable P/N 33-0469 that comes in the kit
  9. Connect the Ground cable and make sure all terminals are tight.  [POWER ON] and test the machine operation.
  5. Install the VMON cable that comes in the kit and connect it to J2 [3].
FIND DISTRIBUTOR
  • Twitter
© 2023 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
