  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      Why Haas MyHaas Education Community Industry 4.0 Haas Certification Customer Testimonials
  • Service
  • Videos
  • MyHaas – One Place for Everything
    • Compare Quotes
      • Compare Quotes
    • About MyHaas
      • About MyHaas
    • Haas CNC Certification Program
    • Haas Learning Resources
    • MyHaas App Form
      • MyHaas App Form
      Haas Tooling Mill Toolholding Mill Workholding Milling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Tool Management Tooling Accessories Package Kits Measuring & Inspection Apparel & Accessories
      HAAS TOOLING QUICK LINKS
      NEW PRODUCTS NEW PRODUCTS
      OPEN TERMS OPEN TERMS
      FINANCING FINANCING
      Haas Service Parts Automatic Pallet Changer Automatic Tool Changer Chip Management Coolant Counterbalance Electrical Cabinet Enclosure Field Install Options Hydraulics Lubrication Maintenance Pendant Probing Rotary Spindle Tailstock
My Cart
Find A Dealer
    4. Español - Méjico
    14. Русский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
Maincon / Mocon / Software - Troubleshooting Guide - CHC
Service Home Maincon / Mocon / Software - Troubleshooting Guide - CHC
Recently Updated Last updated: 02/26/2020
Jump to Section 1. Introduction 2. Symptom Table Back to Top
The Maincon PCB is a combination of two circuit boards, the main processor and the motor controller board are sandwiched into one board. Data buss cables are no longer used unless second Mocon is used. Main processors motor controller, video, network, expanded memory and RS-232 are built onto the board.
An Expansion PCB is added to the back of the Maincon for linear or rotary scales.
  1. Address and Data Buss Ports.
  2. Low Volt Power Supply Input 5V+, 12V-, 12V+.
  3. USB, Ethernet Ports.
  4. Video Output to LCD Screen Port.
  5. SKBIF cable input .
  6. Motor Drive Signal to Servo Amplifiers, Vector Drive.
  7. 510, 520, 530, 540 I/O PCB relay drivers.
  8. Analog Inputs.
  9. 550 Inputs signals from I/O PCB.
  10. Motor Encoder Feedback Inputs.
  11. Backup Battery for BBU memory.
  12. RS-232 Serial Port.
Alarm 239 UNKNOWN MOCON1
Alarm 799 UNKNOWN MOCON2 ERROR
The main software is outdated. The mocon is reporting an alarm that the main software does not support.  Update the software to the latest version in that series.  Note:  After updating the software the correct alarm will be displayed.
The control locks up at the "Haas" logo screen and the Mocon version is scrambled.
The FPGA or Mocon firmware is corrupted.
Reload mocon FPGA and Mocon firmware.
Refer to: Maincon PCB - FPGA Firmware (mcffXXX.rbf) - Upgrade
Maincon PCB - Mocon Firmware (MCFAxxxx.bin) - Upgrade
The FPGA or Mocon firmware upgrade failed.
The control locks up at the "Haas" logo screen and gives message languages not found.
The system languages are corrupted.
Install the languages onto the machine. Make sure to use the same software version that is on the machine.
Internal communications system is not booting up correctly.
Check the voltage from the low volt power supply to the maincon.
The languages are corrupted and the control will not load new languages during a software update.
The software language files are corrupted.
Use this procedure to clear all the language packs from the Maincon PCB.
  1. Press the [POWER ON]  and [PROG/CONVS] button (software load mode).
  2. Wait about 3 minutes to let the internal communications computer boot up.
  3. Type C A100FFF 50S
    Note: There is a space between the C and A and the F and the 5.
  4. Press [WRITE/ENTER].
  5. Wait about 3 minutes before cycling power.
  6. The control will boot up and request the software language packs.
The analog gauges display will show several readings that are not reasonable.
There is a short-circuit at the maincon analog inputs.
Refer to the Analog Sensors - Troubleshooting Guide.
There is electrical noise in the system.
Check that ferrite filters are installed. Refer to electrical noise section in Sigma 5 - Axis Servo Motor and Cables - Troubleshooting Guide.
The machine powers on in monitor mode.
The switch S1 on the Maincon is set "MON".
Make sure the switch is set to "RUN".
Multicolor screens, log out screen, black screen with blue letters, fuzzy screen occur.
A software error occured.
Refer to the following service alerts:
Multi-colored Display
Control Software Errors Can Cause Display Malfunctions
The control has a blurry screen.
A switch on the SKBIF is not set correctly.
Change the MAPSEL switch to the opposite position. Refer to Classic Haas Control - SKBIF / LCD Monitor - Troubleshooting Guide
FIND DISTRIBUTOR
  • Twitter
© 2022 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
