      • VF-4SS
6 - Haas Knee Mill - Troubleshooting
HKM - Knee Mill - Operators/Service Manual
  • 1 -Haas Knee Mill - Introduction
  • 2 - Haas Knee Mill - Safety
  • 3 - Haas Knee Mill - Installation
  • 4 - Haas Knee Mill - Operation
  • 5 - Haas Knee Mill - Maintenance
  • 6 - Haas Knee Mill - Troubleshooting
  • 6.1 Troubleshooting
6.1 Troubleshooting
HKM-1 - Troubleshooting
Under Construction
Overview
The following chapter is a troubleshooting guide for the Haas Knee Mill. This guide includes a table of common issues with the Haas Knee Mill, as well as potential solutions.
SYMPTOM POSSIBLE CAUSE CORRECTIVE ACTION
High backlash on x or y axes Lead screw nut preload too low Adjust backlash. See Section 5.5 Adjust Backlash
X or Y axes cranks are too hard to turn Lead screw nut preload too high Loosen lead screw adjustment nut. See Section 5.5 Adjust Backlash
 High/Low gear lever or quill auto-feed lever is stuck Gears are not meshing properly Rotate spindle by hand to help gears mesh.
Low coolant flow Coolant levels low Refill coolant
Clog Check that all coolant lines and filters are clean and free of chips.
