5 - Haas Knee Mill - Maintenance
HKM - Knee Mill - Operators/Service Manual
  • 1 -Haas Knee Mill - Introduction
  • 2 - Haas Knee Mill - Safety
  • 3 - Haas Knee Mill - Installation
  • 4 - Haas Knee Mill - Operation
  • 5 - Haas Knee Mill - Maintenance
  • 6 - Haas Knee Mill - Troubleshooting
  • 5.1 Maintenance
  • 5.2 Replace Motor
  • 5.3 Replace Speed Change Belt
  • 5.4 Replace Timing Belt
  • 5.5 Adjust Backlash
  • 5.6 HKM-1 - Service Parts List
5.1 Maintenance
HKM-1 - Maintenance
Revision B - 10/2025
This section details the maintenence schedule for the HKM-1, as well as describing lubrication points and laying out a coolant refill procedure. For more information about common maintenence procedures, refer to the other sections of the maintenence chapter.
Maintenance Item Interval
Check the oil level of the lubrication pump
Daily (or before use)
Check coolant level Daily (or before use)
Let machine idle for 3-5 minutes before operations
Grease head Daily (or before use)
Clean work table
Daily (end of workday)
Return sliding components to home position. Restore head to upright position. Daily (end of workday)
Remove tool from spindle Daily (end of workday)
Oil head Twice per week
Clean and oil linear guides. Check that work table moves smoothly in all directions.  Monthly
Check function of brakes and belts Quarterly
Check level of work table and alignment of head  Quarterly
Change lubrication oil Quarterly
Grease and Oil Head
Fill the thumb oil can [1] with 93-4575 SYNTHETIC GEAR/BEARING OIL 1GL/3.78L, 93-2365 SYNTHETIC GEAR/BEARING OIL 1QT/0.94L, or other ISO VG68 Oil.
Use the oil can to fill the three ports [2] on the head of the machine. Fill the ports with 5-10 pumps of oil from the can (approximately 0.33 fl oz or 10 ml).
Note: Do not overfill. Overfilling can cause leaks.
The grease port [3] should be filled with 93-3891 GREASE MOBIL XHP 322 5% MOLY or other EP32 grease.
5.2 Replace Motor
HKM-1 - Replace Motor
Revision A - 10/2025
This section describes how to replace the spindle motor on the HKM-1.
Dismantle Motor
Start the motor and turn the speed dial to 2100 RPM.
Switch off mill and unplug from power source. Remove junction box cover. Disconnect the brake switch wiring [1] and cables U, V and W [2]. Disconnect ground [3].
Pull conduit out of J-box.
Note: Record the wiring configuration of your J-box. If it differs from the example given, disregard the example and re-wire according to your notes.
 Remove three bolts under bearing housing [1]. Insert a flathead screwdriver into each of the gaps in the bearing housing. Lever the bearing housing off of the bearing by pushing down on both screwdrivers at the same time.
Use a flat head screwdriver to remove the bearing [1]. Lever the screwdriver against the slightly wider section of the motor shaft [2]. Levering it against the spring will not provide sufficient leverage.
Use two M6 x 45 bolts [1] to tension the spring. Remove the snap ring [2] from the motor.
Remove the bolts on the motor [1]. Change the motor speed to 4200 RPM.
Pull up to remove the motor. A second person may be helpful to guide the motor out of the casing and ensure that the belt does not get stuck on the shaft.
Replace Motor
Place concave plates [1], tensioning spring, and snap ring [2] on motor shaft.
Loosely loop a zip tie around the speed change belt. Pull on speed change belt to create slack.
Lower motor to 1-2 inches above the motor casing. Use zip tie to pull belt up and around the bottom concave plate.
Rotate motor shaft by hand while pulling the zip tie up and around in the same direction to ease belt in between concave plates.
Lower motor into casing. Snip and remove zip tie before setting motor down. Bolt motor into place [1].
Remove bolts from speed change spring. With a rubber mallet, lightly hammer bearing into place on bottom of motor shaft. Rotate shaft continuously to ensure that bearing does not become crooked.
Place wave ring in bearing housing. Push bearing housing into bearing, and lightly hammer with rubber mallet until bearing housing is within 0.5" of the motor casing.
Continue to push housing onto bearing by incrementally tightening housing bolts [1].
Re-wire J-box.
Note: If the initial wiring of your J-box differs from the example, ignore the example and re-wire according to the initial wiring of your J-box.
HKM-1 - Replace Speed Change Belt
This section describes how to replace the speed change belt on the HKM-1.
Dismantle Motor
Dismantle Speed Change Belt Assembly
Remove drawbar cover [1].
Disconnect pneumatic lines from drawbar actuator [1].
Unbolt drawbar actuation assembly [1].
Insert bolts from drawbar actuation assembly into specified holes on the bearing housing. Tighten the bolts incrementally in a star pattern to lift the bearing housing pins [1]. Remove bearing housing [2].
Remove bolts and bolt sleeves [1] from speed change bracket.
Remove bolts under gear housing [1]. Lift off gear housing. Speed change belt can now be removed and replaced.
Rebuild Speed Change Assembly
Replace gear housing. Replace sleeves and bolts on speed change housing [1].
Using a screwdriver or other long tool, press upwards under the top concave plate to ensure that it is all the way at the top of the shaft.
Replace bearing housing. Tighten bolts in a star pattern [1].
Replace drawbar actuator and pneumatic lines.
Replace drawbar cover. For information on re-installing the motor, see Replace Motor section above.
Replace Motor
Re-wire J-box.
HKM-1 - Replace Timing Belt
This section describes how to replace the timing belt on the HKM-1.
Dismantle Motor
Replace Timing Belt
Remove top plate from timing gear [1]. Pull belt off of timing gear.
Remove snap ring from drawbar shaft [1]. Lift off top concave plate [2].
Unbolt brake housing [1] and lift off brake assembly. The timing belt may now be removed and replaced.
5.5 Adjust Backlash
HKM-1 - Adjust Backlash
This section describes how to adjust the backlash on HKM-1.
Adjust Y-Axis Lead Screw
Remove two bolts on the table [1] and the front of the knee [2]. Remove the front way cover.
 Turn the y-axis crank counterclockwise to move the saddle to the front of the knee.
Remove the four bolts [1] on the y-axis bearing bracket.
Engage the Y-axis lock [1]. Turn the y-axis handle clockwise [2] while supporting the bearing braket. The pins will seperate from the saddle.
Extrude the ballscrew until the ballscrew adjustment tool can fit into the housing. Insert the larger side of the ballscrew adjustment tool into the saddle until it touches the lock nut. Rotate the adjustment tool around the ballscrew until both halves slide into the slots on the lock nut.
Turn the adjustment tool once counterclockwise to loosen the lock nut.
 Insert the smaller side of the lead screw adjustment tool into the saddle. Rotate the adjustment tool around the lead screw until both halves slide into the slots on the adjusting nut.
Turn the adjustment tool to adjust the preload on the lead screw. Test the backlash by turning the axis handle. Adjust the preload until the backlash is between 0.003-0.005" (0.08 to .13 mm). Tighten the lock nut.
While supporting the y-axis bearing bracket [1], turn the y-axis handle counterclockwise to retract the lead screw. Re-install the bearing bracket and way cover.
Adjust X-Axis Lead Screw
Move the table to the center of the y and x axes. Insert the larger end of the adjustment tool under the left side of the table. Rotate the tool once counterclockwise to loosen the lock nut.
5.6 HKM-1 Service Parts List
HAAS Knee Mill - Service Parts List
Revision E - 03/2026
The following section lists the service parts that are available to order for HKM-1. To order a part that is not included in this list, please view the exploded views below and contact Haas Service with the sub-assembly name and part number.
For example, if a user plans to order a leveling pad for an HKM-1 machine, they should request Machine Body Assembly - Machine Body Unit Part #6. Other information, such as pictures of broken parts or informal names for parts, can also be included when additional context is needed.
HKM-1 Exploded Views
MACHINES Part Number Description
HKM-1 93-4884 BELT, VARIABLE SPEED HKM-1
93-4885 BELT, TIMING HKM-1
93-4886 BRAKE SHOES HKM-1
93-4887 BRAKE SHOE SPRING HKM-1
93-4888 QUILL CLOCK SPRING & COVER Z-AXIS HKM-1
93-5170 AIR REGULATOR BRACKET HKM-1
93-5590 AIR POWER DRAWBAR UNIT HKM-1
93-5583 POWER FEED X-AXIS HKM-1
93-5541 POWER FEED HKM-1
93-5539 BELT 38MM X 890MM HKM-1
93-5538 TIMING BELT HKM-1
93-5537 COOLANT PUMP MOTOR HKM-1
93-5865 SOLENOID AIR VALVE HKM-1
93-5866 LED WORK LIGHT ASSEMBLY HKM-1
93-5953 RAM UNIT TILT WORM GEAR HKM-1
93-5954 RAM UNIT SPRING PIN HKM-1
93-5955 HEAD ASSY WORM SHAFT HKM-1
93-5956 HEAD LEFT/RIGHT TILT WORM SHAFT HKM-1
93-5957 HEAD ASSY DOUBLE ROUND KEY HKM-1
93-6084 16A THERMAL OVERLOAD RELAY HKM-1
93-6085 HANDLE LEVER HKM-1
HKM-1 CE 93-5614 TABLE GUARD UNIT CE HKM-1
93-5613 SPINDLE GUARD UNIT CE HKM-1
