Pneumatic Chuck HRT 210 - Installation - AD0882
Service Home How To Procedures Pneumatic Chuck HRT 210 - Installation - AD0882
- Jump to Section - 1. Introduction (6 steps) Back to Top
Recently Updated Last updated: 05/29/2025
AD0882
Revision A - 5/2025
The following procedure will guide you through the installation of the pneumatic 3-jaw air chuck on an HRT-210.
The following installation applies to the following kit
  • 08 - 1931 HRT210 AIR CHUCK KIT
Important: The machine must meet the necessary requirements before installing the 3 - Jaw Air Chuck. The programmable air option must be installed prior to this procedure. Refer to Programmable Air - Installation for more information.
Air Chuck Installation
Important: Before installing the chuck be sure to shut off air to the machine and bleed out the air from the main manifold in the machine's lube cabinet.
Using the hardware kit that was provided with the chuck, install the 6 T- Nuts  into the T- Slots of the HRT's Platter [1].
Using the 6 x M12 socket head cap screws install the adapter plate to the HRT's platter [2].
Using the six socket head cap screws provided with the air chuck, align the air chuck with the adapter plate and torque the bolts to securely fasten the chuck to the plate.
Note: When installing the air chuck to the adapter plate ensure that the following airports are located on the left side of the rotary as shown [2].
Using the bracket provided in the kit, remove the two button head cap screws located at [1], then attach the bracket using those same screws.
Install one of the extra fasteners provided in the kit into the top mounting hole of the chuck [2].
Note:  This top screw will serve as an anti-rotation stop, preventing the plate with the chuck’s air ports from rotating a full 360 degrees and causing the hoses to bind once installed.
Using the fittings provided from the installation kit install the two 1/4 NPT Female  x 1/4 NPT Male to the 3 - Jaw Air Chuck [1].
Install the two 90-degree 1/4 NPT Male x 1/4 NPT Male to the two female fittings [2].
Remove the current 1/4 inch fittings on the programmable air manifold.
Note: When removing the original fittings, make sure to note which port is for clamping and which is for unclamping, as this information will be needed in the next step.
Using the two 1/4 NPT Male x 1/4 NPT male fittings install them to the programmable air manifold [1].
Using the one of the hoses provided in the kit, route the 1/4" female-ended hose from the air manifold to the unclamp fitting on the air chuck [1].
Use the remaining hose provided in the kit, and route the 1/4" female-ended hose from the air manifold to the clamp fitting on the air chuck [2].
Note: Use the Rotary Cable Management Kit to secure excess hoses and prevent them from hanging loosely inside the machine. Refer to the Rotary Cable Management Installation Guide for more information.
Setup
Before enabling the vise press [SETTING], find Setting 276 and make sure the value is 15.
Press [CURRENT COMMAND] and navigate to the Work holding tab under the Devices tab.
Highlight the vise you want to setup [1] and press [ALTER] to setup the vise [2].
Press [E-Stop]
Press the right arrow on the keyboard to change the value from NONE [1] to 3:Custom Pneumatic Vise [2].
Make sure the vise clamps/unclamps correctly by pressing F2 [1].
Note: If the vise is not clamping/unclamping correctly, check the hoses routed to the programmable air manifold and reverse them if necessary.
