40 Taper - Inline and SS - Spindle Fan Shroud - Repair - AD0147
Service Home How To Procedures 40 Taper - Inline and SS - Spindle Fan Shroud - Repair - AD0147
Recently Updated Last updated: 06/07/2022
AD0147
Applies to machines built from: July, 2014
- Jump to Section - 1. Introduction 2. Installation (7 steps) 3. Assembly Back to Top
This procedure tells you how to repair the cooling fan supports on the spindle motor shroud in a 40-Taper inline drive or super-speed mill. Do this repair if one or more of the (4) spindle-fan mounting tabs on the motor shroud is broken.
Inline MTR Shroud Fan Mount Service Kit (P/N 93-2247)
Power off the machine.
Turn off and then Lockout/Tagout the main circuit breaker.
Remove the spindle head covers.
Disconnect the spindle fan cable [1] from the spindle-head connector bracket.
Remove the spindle motor shroud [2].
 Note: The mounting hardware and the spindle connector panel are different for each machine model.
Remove the fan shroud assembly [1].
Remove the fan support bushings [2].
Use pliers to bend each of the (4) spindle-fan mounting tabs back and forth until it breaks off of the motor shroud.
If the motor shroud has an internal overlap [1] on the side seam (P/N 25-1599C):
Cut a 0.75" x 0.75" (19 mm x 19 mm) notch [2] in the upper edge of the motor shroud.
Make sure that the notch removes the side seam [3] to make space for the fan bracket.
Attach the (2) fan brackets [1] to the bottom of the fan shroud assembly.
Insert the assembled fan shroud assembly into the top of the motor shroud [2].
The fan brackets rest on the top edge of the motor shroud.
Make a circle mark [2] for the (4) fan-bracket mounting holes [1] on the sides of the motor shroud.
Remove the fan shroud assembly [3].
Drill a 0.25" (6.4 mm) hole in each of the (4) circle marks.
Assembly
Remove the fan brackets [1] from the fan shroud assembly.
Use the (4) BHCS and nuts included in the kit to attach the fan brackets over the top edge of the motor shroud [2].
Attach the fan shroud [3] to the fan brackets.
Attach the motor shroud [1] to the spindle casting.
Connect the spindle fan cable [2] to the spindle head connector bracket.
Install the head cover.
