Bearingless TSC Rotary Union - Leak Prevention - DT-1 - AD0093
Service Home How To Procedures Bearingless TSC Rotary Union - Leak Prevention - DT-1 - AD0093
Recently Updated Last updated: 01/18/2019
AD0093
Applies to machines built from: August, 2013
- Jump to Section - 1. Introduction 2. Parts Required 3. Bearingless TSC Rotary Union - Leak Prevention - DT-1 (11 steps) Back to Top
This procedure tells you how to prevent the bearingless TSC rotary union leaks that can occur when you use tools with an outside diameter (OD) of less than 0.200". After this kit is installed, command tool changes instead of M89 to prevent coolant leaks with all tools, including those of OD less than 0.200".
Parts Required
  • Kit P/N 93-2181
Install a hose clamp to a bolt on the top of the enclosure behind the air/lubrication panel.
Feed the coil of the accumulator hose, included in the kit, through the hose clamp.
Let both ends of the hose hang down below the air/lubrication panel.
Open the air/lubrication panel door.
Disconnect the 1/4" TSC piston air hose from the TSC piston solenoid.
Make a 1/2" line adapter assembly from the following parts:
  • [1] FITG LBO-3/8 X NPT-1/4M STR GREASE & OIL
  • [2] FITG NPT-1/8-M X NPT-1/4-F STR
  • [3] FITG LBO 1/4 X 1/8 NPT F STR.
Make (2) assemblies.
Connect the 1/4" TSC piston air hose to a 1/2" line adapter assembly.
Connect the other end of the 1/2" line adapter assembly to one end of the accumulator hose.
Connect a 1/2" line adapter assembly to the other end of the accumulator hose.
Connect the 1/2" line adapter assembly to the 1/4" inch hose included in the kit.
Connect the 1/4" hose in the kit to TSC piston solenoid.
Remove the muffler from the TSC piston solenoid.
Install the plug supplied with the kit into the TSC piston solenoid exhaust port.
Test the TSC system. Make sure there are no leaks in the air hoses and coolant hoses.
