Rotary - Hydraulic Brake Booster Retract Air Line - Installation - AD0404
Service Home How To Procedures Rotary - Hydraulic Brake Booster Retract Air Line - Installation - AD0404
Recently Updated Last updated: 12/10/2018
AD0404
- Jump to Section - 1. Installation Back to Top
Shut the machine OFF and disconnect the air supply from the machine before performing this procedure.
Note: This procedure shows how to add the retract line, 93-2868, to the single rotary axis. The location of the booster will vary. The UMC-750SS has the brake boosters for both B and C axes mounted behind the B axis rotary body. The UMC-750/P has the brake booster mounted on the side of the B axis rotary body. The EC-1600/ZT/5AX has the brake booster mounted to the front of the table.
Locate the rotary brake solenoid [1] in the CALM cabinet.
Remove the plug [2] from the Normally Closed (NC) port on the solenoid and install the push-to-lock fitting [3]
Locate the corresponding brake booster [4] and install the fitting adapter [5] and the push-to-lock fitting on the "retract" port [7] on the air cylinder.
Route the air line from the NC port of the solenoid to the "retract" port on the air cylinder.
Connect the air supply to the machine. Power the machine ON and test the rotary brake operation.
Reference Material
  • UMC-750SS - B-Axis and C-Axis Rotary Brakes - T-0062 Bleed Instructions
  • Rotary Brake - Bleed Instructions - EC-1600
  • Solenoid - Troubleshooting Guide
