      • Coating Thickness Gauges
      • Hardness Tester
      • Portable EDM
      • Rotary Workholding Kits
      • Parts Wash-Off Tools & Kits
Rotary Brake - Bleed Instructions - EC-1600
Service Home How To Procedures Rotary Brake - Bleed Instructions - EC-1600
Recently Updated Last updated: 11/29/2018
- Jump to Section - 1. Introduction 2. Machine Compatibility 3. Tools Required 4. EC-1600 - Rotary Brake - Bleed Instructions - Evaluation (1 step) 5. EC-1600 - Rotary Brake - Bleed Instructions (3 steps) Back to Top
This procedure tells you how to evaluate and bleed the rotary brake on an EC-1600 horizontal mill using the rotary bleed tool [1].
EC-1600 horizontal mills made after September 2015.
Tools Required
  • Part number T-0062A, Rotary Bleed Kit
  • Mobil DTE 24 Hydraulic Oil
  • Table bolt plug (Part Number: 22-9087)
  • Digital multimeter
  • Magnetic 5mm Hex Key
Push [ZERO RETURN] [ALL].
Push [EMERGENCY STOP].
Disconnect the sensor cable from the B-Axis booster unit.
Connect the leads from a digital multimeter to the sensor contacts [1].
Release the [EMERGENCY STOP].
Operate an M10; code to clamp the B-Axis brake. Then operate an M11; code to unclamp it.
  • The multimeter shows OL (open) when the brake is clamped, and 0.1 to 0.4 Ohms when it is unclamped.
  • You must bleed the brake if the multimeter display does not change when the brake clamps and unclamps.
Remove the table-bolt plug [1] from the hole in the table that is closest to the spindle.
Jog the A Axis until the 5 mm bleed plug [2] at the bottom of the hole can be removed.
Set the main air supply valve to the OFF position. This shuts off air to the machine.
Pull the ring on the pop-off valve [3] on the main manifold to release air pressure in the system.
Use a magnetic 5mm hex key to remove the plug from the access port at the bottom of the hole. Do not remove the o-ring from the plug.
Attach the 5/16-24 SAE-ORB MALE x 1/8 NPT FEMALE fitting [1], included with the tool, to the fitting [2] at the end of the rotary-bleed tool.
Insert the rotary-bleed tool [3] into the access port. Use your fingers to tighten the tool into the port.
 Note: If the 5/16-24 SAE-ORB MALE x 1/8 NPT FEMALE fitting does not reach the access port, you must grind the body of the fitting until it fits through the table. Make sure to not damage the threads on the fitting.
Close the ball valve [4] and fill the rotary-bleed reservoir with oil.
Open the main air valve. This moves the brake piston forward to the pressurized position.
Slowly open the rotary-bleed tool ball valve. Wait for the bubbles in the rotary-bleed tool reservoir [1] to stop.
Close the main air valve. This returns the brake piston to its unpressurized position. Pull the pop-off valve on the main manifold to release the air pressure in the system.
Oil flows backwards through the system. It eventually fills the master cylinder and the main reservoir.
 Caution: Keep the rotary-bleed tool reservoir full. Do not let air back into the rotary table.
When bubbles stop flowing into the main reservoir [2], close the ball valve on the rotary-bleed tool.
Repeat this step until no more bubbles are in the system.
Set the main air supply valve to the ON position.
Clamp the break and make sure you get between 700-750 psi on the pressure gauge [3].
Unclamp the break and remove the rotary-bleed tool.
Use a magnetic 5mm hex key to install and tighten the bleed plug into the port.
Install a new table-bolt plug into the hole in the table.
Repeat the Evaluation procedure.
