      • Coating Thickness Gauges
      • Hardness Tester
      • Portable EDM
      • Rotary Workholding Kits
      • Parts Wash-Off Tools & Kits
Sigma 1 to 5 Motor Conversion - Installation - AD0681
Service Home How To Procedures Sigma 1 to 5 Motor Conversion - Installation - AD0681
- Jump to Section - 1. Introduction 2. Installation (1 step) 3. Wiring (2 steps) Back to Top
Recently Updated Last updated: 05/13/2025
AD0681
Revision A - 5/2025
This procedure tells you how to install the Sigma 1 to 5 conversion service kit on a machine with a Classic Haas Control.
Machine Compatibility:
  • Lathe Classic Haas Control 9.04 software version or lower.
    NOTE:  No parameter changes are necessary.
  • TL-1/2 with TT4 turret
NOTE:  TT-4 turrets made between 09/2004 - 12/2014. For turret installation information, refer to TL-1/2 - TT-4 and ATT-4/8 Turret - Motor Replacement - AD0195 procedure.
  • HRT110
  • TR110
Note:  This kit will not work with any other rotary with a Sigma 5 motor. HSG - N 2/23/2024
Service Kits:
  • 93-3808 SIGMA 1-5 CONVERSION BOX AXIS KIT [1] contains the Sigma translator assembly, the PCB that converts the motor's Sigma 5 signals to Sigma 1 signals for the machine to read.
  • 93-3807 SIGMA 1-5 CONVERSION CONTROL KIT [2] contains the Sigma translator assembly power cable and mounting kit.
 IMPORTANT: When upgrading the motor from Sigma 1 to 5:
  • 93-3808 SIGMA 1-5 CONVERSION BOXS AXIS KIT [1] is required for each axis that a Sigma 5 motor is installed on.
  • 93-3807 SIGMA 1 TO 5 CONTROL KIT [2] only one is needed for each machine
Once each motor is installed on each axis getting an upgrade, install the conversion kit:
On the Maincon/MOCON locate the Axis Encoder Cable from the motor that is being replaced. Disconnect the Axis Encoder input cable from the Maincon/MOCON.
Mount the mounting plate [1] on top the maincon/MOCON using standoffs.
Stick the edge protector [2] over the edge.
Attach the sigma convertor [3] on top of the mounting plate [1].
NOTE: If the sigma convertor holes don't line up perfectly with the mounting plate holes, use a drill bit to slightly widen the sigma convertor hole as needed.
Wiring
MOCON & Main
Inside the control cabinet, insert the encoder cable from the machine into the sigma convertor [1] encoder end.
The translator cable is routed from the sigma convertor [1] control end to the axis encoder input on the MAINCON [2].
The power cable plugged into MOCON J6 [3] to the PSUP should be removed. Connect the new power cable from the MOCON J6 [3] to PSUP P33. Connect the new power cable pigtail to the translator cable pigtail [4].
 IMPORTANT: If installing a second sigma converter assembly [5], connect the first translator cable pigtail with the second translator cable pigtail [6] in order for it to receive power. Repeat this process for each sigma convertor.
MAINCON
The power cable plugged into MAINCON P19 [3] to the PSUP should be removed. Connect the new power cable from the MAINCON P19 [3] to the removed connector on the PSUP (either P30 or P33). Connect the new power cable pigtail to the translator cable pigtail [4].
