    26. Українська
    26. Українська
SMTC-30/50 Air Cylinder Replacement
Service Home How To Procedures SMTC-30/50 - Air Cylinder - Replacement
Recently Updated Last updated: 04/12/2021
- Jump to Section - 1. Introduction 2. Replacement (5 steps) Back to Top
This procedures tells you how to replace the air cylinder on the SMTC-30/50.
Replacement
Remove the sheet metal covers.
Remove three adjacent pockets.
Rotate the carousel so the center removed pocket is in position.
Shut off the main air supply to the machine.
Unplug the top air cylinder hose [2] (green).
Use a 1/4" ball-end allen wrench to remove the (4) top cylinder mounting bolts [1].
Unplug the lower air cylinder hose [1] (red) and remove the pocket up/down proximity sensors [2].
Remove the (4) mounting bolts for the pocket slide assembly.
The pocket slide assembly is on (2) alignment pins. Pull the slide assembly off the pins and drop the slide and cylinder out of the tool changer.
Remove the roller [1] from the cylinder side of the pocket slide assembly.
Remove the cylinder from the pocket slide.
Remove the bushing [2] and air fittings [4] and install them on the replacement cylinder. Thread the bushing [2] all the way on the cylinder shaft, then back it off approximately two turns so there is a 1/8" gap [3] between the flange on the shaft and the jam nut.
Loosen the cylinder jam nuts [5] and back off the set screws until they stop then tighten the jam nuts.
Re-assemble the pocket slide and install the cylinder in the reverse order they were removed.
Turn on the main air supply and test the pocket up/down cylinder. Re-install the sheet metal covers.
