    4. Español
    14. Постсоветский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
      • Drill/ Tap/ Mill Series
      • Robot Packages
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
      • VF-2SS
      • VF-2SSYT + Pallet Pool
      • 05-0258
      • 08-1760
      • 08-1760
      • 08-1761
      Haas Tooling
      Haas Tooling View All
      Inventory Sale Inventory Sale Mill Toolholding Mill Workholding Tombstones Manual Chucks For Milling Mill Tooling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Broaching Tool Presetter & Heat Shrinkers Tooling Accessories Deburring & Abrasives Package Kits Apparel & Accessories Tool Storage Measuring & Inspection Winner's Circle Winner's Circle
    • All Sale Items
      All Sale Items Shop All
      • Drill Chucks
      • Pull Studs
      • Burrs
      • Fixed Jaw Vises
      • Reduction Sleeves
      • Cut-Off Tooling
      • Threading Toolholders
      • Small ID Grooving & Threading Tools
      • Grooving Tools
      • Boring Bars
      • OD Toolholders
      • Haas Notch Groove & Thread Inserts
      • Haas Notch Groove & Thread Toolholders
      • Lathe Collet Chucks
      • Lathe Boring Rings
      • Mill Toolholding Kits
    • Inventory Sale
      Inventory Sale Shop All
      • Drill Chucks
      • Pull Studs
      • Fixed Jaw Vises
      • Mill Vise Jaws
      • Workholding Accessories
      • Burrs
      • Cut-Off Tooling
      • Grooving Tools
      • Boring Bars
      • OD Toolholders
      • TL & CL Toolholding
      • BOT Toolholding
      • BMT Toolholding
      • Live Toolholding
      • Reduction Sleeves
      • VDI Toolholding
      • Spindle Liners
      • ER Collets
      • Straight Shank Keyless Drill Chucks
      • Broaching Toolholders
      • CNC Clearing Fans
      • Spare Parts
      • Lathe Tooling Kits
      • Test Bars
      • Inspection Kits
      • Tool Setting Measuring Gauges
    • Deals Of The Week
      Deals Of The Week Shop All
      • Grooving Tools
      • Cut-Off Tooling
      • Boring Bars
      • OD Toolholders
    4. Español
    14. Постсоветский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
ST-20 Sub-Spindle Hose Routing Retrofit Kit
Service Home How To Procedures ST-20 Sub-Spindle Hose Routing Retrofit Kit
Recently Updated Last updated: 11/16/2020
AD0472
- Jump to Section - 1. Introduction 2. Remove Existing Sub-Spindle Enclosure (1 step) 3. Install New Sub-Spindle Enclosure (2 steps) Back to Top
This kit fixes an issue with a grommet leaking coolant out the front side of the ST-20 re-boot enclosure. It makes a small adjustment to how the hydraulic drain line hose is routed to the grommet to prevent cable movement which can cause cracks in the sealant around the grommet.
  • Applicable to ST-20 re-boot machines built between April 2019 to November 2019.
  • Retrofit kit P/N: 93-3127
  • Remove the back cover and cable bracket [2]
  • Remove the fan and install to new back cover
  • Remove the head cover [1]
  • Remove the hose from the exisiting hydraulic fitting and remove the fitting [1]
  • Install the new elbow hydraulic fitting [2] to the hose and hydraulic union
  • Install the new head cover [1] and the cable bracket
  • Install the new back cover [2] with the hydraulic drain hose through the new cut-out location [3]
  • Use the cable clamp to secure the drain hose using the exisiting button head cap screw on the sheet metal skirt of the sub-spindle
  • The drain hose will still be routed through the grommet, but will move much less now
  • If the sealant around the grommet has cracked, re-seal the grommet and let cure for 24 hrs before jogging the sub-spindle
FIND DISTRIBUTOR
  • Twitter
© 2023 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
