      • Coating Thickness Gauges
      • Hardness Tester
      • Portable EDM
      • Rotary Workholding Kits
      • Parts Wash-Off Tools & Kits
ST Lathe Belt Shroud Kit Installation - AD0479
Service Home How To Procedures ST Lathe Belt Shroud Kit Installation - AD0479
Recently Updated Last updated: 04/13/2021
AD0479
Applicable dates and models are listed in each section below. What is shown is current kit availability.
- Jump to Section - 1. ST-10 Belt Shroud Kit 93-3105 (06/2019 - 08/19/2020) (1 step) 2. ST-15 (02/2016-Present) and ST-20 (4k 2018 only) Belt Shroud Kit 93-3121 (1 step) 3. ST-25 Belt Shroud Kit 93-3262 (3/19/2018-3/13/2020) (1 step) 4. ST-20 5K Spindle Belt Shroud Kit 93-3263 (3/1/2019-3/12/2020) (1 step) Back to Top
  • This kit can be installed on ST-10 machines built 06/2019 to 08/19/2020.  To check compatibility make sure the ibase of this machine shows a spindle head assembly of 30-5647E or later.
  • Bolt on the rear spindle belt shroud covers with the screws labeled [1]
  • Install the screws labeled [2]
    • If this machine has the spindle head casting 20-6771F then you will need to tap 1/4"-20 screw holes in the locations labeled approximately a 1/2" deep[2]
    • Drill Size: #7 drill (13/64")
    • Tap Size: 1/4"-20 UNC 2B
  • Install the front spindle belt shroud cover using the screws in the locations labeled [3]
  • This kit fits:
    • ST-15 machines built 02/2016 to Present
    • ST-20 4k machines built in 2018 with the spindle option 37-3852 SPNDL OPT A2-6 4.0K 2"ID ST20 2018.  If your machine does not have this part number in the ibase as the spindle option, then this kit will not work for your ST-20.
  • Install:
    • Install the rear panel screws to the motor mount [1]
    • Button the two panels together using the nuts [1]
    • Use a standoff and socket head cap screw to secure the shroud to the spindle casting [2]
      • Some casting variations may not require this standoff
  • This kit fits:
    • ST-25 machines built 3/19/2018 to 3/13/2020 with the spindle option 37-3851 SPNDL OPT A2-6 3.4K 3"ID BL ST25/30 2018.  If your machine does not have this part number in the ibase as the spindle option, then this kit will not work for your ST-25.
  • Install:
    • Install the rear panel screws to the motor mount [3]
  • This kit fits:
    • ST-20 machines built 3/1/2019 to 3/12/2020 with the spindle option 37-4302 SPNDL OPT A2-6 5.0K 2.5"ID ST20 2018. If your machine does not have this part number in the ibase as the spindle option, then this kit will not work for your ST-20.
  • Install:
