VMT Brake Booster Regulator Service Kit - AD0605
Service Home How To Procedures VMT Brake Booster Regulator Service Kit - AD0605
Recently Updated Last updated: 03/22/2022
AD0605
- Jump to Section - 1. Introduction (4 steps) 2. Removal (2 steps) 3. Installation (2 steps) Back to Top
TThis procedure outlines how to install and properly set the Brake Regulatir Service Kit on all Reboot VMT models.
This document applies to:
  • 93-3512 BRAKE REGULATOR RETROFIT KIT VMT
 You should not do mechanical or electrical machine repairs or service procedures unless you are qualified and knowledgeable about the processes.
  Only authorized personnel with the proper training and certification should do this repair procedure.
  All information herein is provided as a courtesy for Haas machine owners for reference and illustrative purposes only. Haas Automation cannot be held responsible for repairs you perform. Only those services and repairs that are provided by authorized Haas Factory Outlet distributors are guaranteed.
Removal
  • Jog the X Axis up to the Max travel.
  • Press the Emergency Stop
  • Rotate the ball valve shown to cut off air the machine.
Note: The wings of the valve should be perpendicular to the pipe.
  • Purge excess air pressure from the machine by pulling and holding the ring on the purge valve until you no longer hear air escaping.
  • Remove the rear spindle head panel to gain access to the Brake booster.
Remove the Blue Air Line [1] from the B-Axis booster
Remove  the adapter and 90° elbow fitting [2] from both brake boosters.
  • Brake Booster Regulator kit [1] will come with the stright fitting [2] removed.
  • Install Regulator kit [1] on the Brake boosters.
  • install the stright fitting [2] onto the regulator kit, followed by the Blue air line.
Note: The fitting for Brake Retract line may need to moved for clearance when installing Regulator kit.
  • Rotate the ball valve shown to open air the machine
Note: The wings of the valve should be parallel to the pipe.
  • Adjust the brake regulators to 70 PSI.
  • Install the rear panel
  • Release the Emergency Stop
  • Test the B  brake function properly.
