Machine Ambient Temperature Sensor Location – Identification
Service Home Machine Ambient Temperature Sensor Location – Identification
Recently Updated Last updated: 10/23/2024
Machine Ambient Temperature Sensor Location - Identification
- Jump to Section - 1. Introduction 2. CM / CL Identification 3. UMC Identification 4. ST - Lathes Identification 5. VF-6/7/8/9/10/11/12 Identification 6. DM / DT, MM & TM Identification 7. EC Identification 8. HDC-3-5AX Identification 9. VS - 1/3 Identification 10. GR - 510/712 Identification 11. GM-2 / GM-2-5AX Identification Back to Top
Some machines come with a preinstalled temperature sensor to track the machine's casting temperature level. This temperature sensor is attached to different locations on different machines shown below.
 IMPORTANT: This sensor is for informational purposes only. It will not affect thermal compensation.
Machine Requirements:
Machines Manufactured by Date
CM / CL 11/15/2022
UMC 11/28/2022
ST- Lathes 08/01/2023
VF-6/7/8/9/10/11/12 9/27/2023
DM / DT 11/01/2023
MM 11/01/2023
TM 11/01/2023
EC-1600/YZT/ZT Before 3/01/2024
EC-1600/YZT/ZT After 3/01/2024
HDC-3-5AX 4/01/2024
VS - 1/3 8/01/2024
GR-510/712 8/01/2024
GM-2 / GM-2-5AX 9/30/2024
EC-400/500/630 8/01/2024
VC-400 10/22/2024
  Note: All ST- Standard Lathes except ST - 15/25/28/35/L
CM Temperature Sensor:
The temperature sensor [1] is installed onto the back of the CM column casting. It is located behind the Z axis servo motor.
The sensor cable [2] is routed with other cables into the control cabinet.
CL Temperature Sensor:
The temperature sensor [1] is installed onto the CL base casting. It is located behind the Z axis servo motor.
The sensor cable [2] is routed with other cables through the back of the base casting and around the perimeter of the machine into the control cabinet.
UMC Identification
UMC 350 Temperature Sensor:
The temperature sensor [1] is installed onto the UMC 350 bridge casting underneath the X axis proximity sensor mount [2].
The sensor cable [3] is routed with other cables directly into the control cabinet.
UMC 500 - 1500 Temperature Sensor:
The temperature sensor [1] is installed onto the back of the UMC base casting on the control cabinet side.
The sensor cable [2] is routed with other cables directly into the control cabinet.
ST-10/L Temperature Sensor:
The temperature sensor [1] is installed onto the ST-10/L base casting. It is located behind the Z axis support head.
ST-20/30/L Temperature Sensor:
The temperature sensor [1] is installed onto the ST-20/30/L casting. It is located between the Z axis servo motor and the Z axis support head.
ST-40 Temperature Sensor:
The temperature sensor [1] is installed onto the ST-40 casting. It is located to the right of the Z axis servo motor and above the right Z axis linear guide rail.
The temperature sensor [1] is installed onto the top of the VF-Large column casting. It is located behind the Z axis servo motor to the left.
The temperature sensor [1] is installed onto the top of the DM/DT, MM & TM column casting. It is located behind the Z axis servo motor.
EC Identification
EC-400/500/630 built after 8/1/2024 and VC-400 built after 10/22/2024 Temperature Sensor:
The temperature sensor [1] is installed onto the front left side of the base casting next to the electrical connector bracket.
The sensor cable [2] is routed with other cables through the front of the base casting into the control cabinet.
EC-1600/YZT/ZT built before 3/1/2024 Temperature Sensor:
The temperature sensor [1] is installed onto the front of the EC-1600 column casting. It is located behind the Z-Axis ball screw.
The sensor cable [2] is routed with other cables through the back of the column casting into the control cabinet.
EC-1600/YZT/ZT built after 3/1/2024 Temperature Sensor:
The temperature sensor [1] is installed onto the EC-1600 base casting. It is located forward of the tool changer.
The sensor cable [2] is routed along the perimeter of the machine towards the back of the column and into the control cabinet.
The temperature sensor [1] is installed onto the top of the HDC-3-5AX Bridge casting.
The sensor cable [2] is routed through sheet metal into the bridge and routed with other cables into the control cabinet.
The temperature sensor [1] is installed onto the VS base casting. It is located underneath the control cabinet.
The sensor cable [2] is routed up into the control cabinet.
The temperature sensor [1] is installed onto the base casting rail near the operator. It is located towards the back, under the table.
The sensor cable [2] is routed through the back of the base casting with other cables into the control cabinet.
The temperature sensor [1] is installed onto the base casting rail near the control cabinet.
The sensor cable [2] is routed into the control cabinet.
