Release Notes Rev FV 14.011 9/7/2012
Recently Updated Last updated: 08/13/2018
This task provides the following improvements/fixes for the WinCE side of the control:
Fixes below do not require any Mill or Lathe control software change.
  1. When DHCP is turned off, the control can still retrieve a MAC address by using a file located on the hidden partition of the hard drive. Conversely, whenever the adapter returns a valid MAC address this information is saved back the file. A valid MAC address should be available at the time the machine leaves the factory. The file is located at LOGS\MAC_ADDR.TXT
  2. There was a problem when searching for single letter characters such as Gin FNC edit. The search would place the cursor on the next item shown being searched for. This has been corrected.
  3. Attempting to save a file with an invalid filename could cause the control to lockup depending on the particular filename (ie. A filename of ‘\’ locks up the control). A function has been added to check for invalid characters within the filename.
  4. When searching for a token that contained a numeric value followed by a decimal point (e.g. ‘F100.’), the search failed to find the token. This has been corrected.
  5. An improvement was made to increase the amount of USB keys that will mount to the control.
Fixes below work in conjunction with Mill 18.11A or Lathe 11.08A.
  1. HTML help search has quicker response.
  2. In the past, if the command input line was too long during a replace all function, the editor would display an error (or blue screen). This has been corrected.
  3. There was a fix to the replace all function that may lock up the control. This has been corrected.
  4. There was a problem with selecting and moving blocks of text within an FNC edit. The text would be moved to an incorrect location if attempting to move the text to a point after the selected text. This has been corrected.
  5. An enhancement was made to alert the operator if a USB device fails to mount after a period of time.
  6. The FNC editor now prevents a user from changing O-codes. Any attempt to change an O-code will result in a message that states "Guarded code". Any attempt to replace any other token with an O-code will result in a message that states "BAD CODE".
  7. There was a problem when removing all the line numbers from an FNC edit program that stopped all FNC editing capabilities. This has been corrected.
