Haas Pneumatic Vise (UMC Series) - Troubleshooting Guide
Service Home Haas Pneumatic Vise (UMC Series) - Troubleshooting Guide
Recently Updated Last updated: 02/11/2022
- Jump to Cause - Back to Top
The UMC series machines have two types of workholding and vises: hydraulic [1] and pneumatic [2]. This troubleshooting guide will have information in regards to the pneumatic workholdings [2].
For further information on how to install the pneumatic workholding mechanisms/vises please refer to the links below:
Pneumatic Workholding Links
  • Pneumatic Workholding Installation (mechanism)
  • Pneumatic Vise Installation
Symptom Probable Casue Corrective Action
Vise jaws are not closing when commanded and air booster is functioning properly Verify orientation of the ports between the coupler and the spud of the vise. The open and close ports may be lined up with the air blast port.   Remove the vise from the platter and verify if the orientation is correct. Newer versions of the coupler will have the air port labeled "AIR"
Alarm 391 FEATURE DISABLED Workholding is not setup on Workholding Tab. Enable the workholding on the Workholding tab. See the Programmable Air - Installation procedure for more information.
Message: Foot pedal 1 is locked out. The foot pedal is pressed when in the EDIT mode or LIST PROGRAM mode. Navigate off of the EDIT mode or LIST PROGRAM mode.
Broken dove tail jaw. Incorrect part setup on jaws. Refer to the Proper Dovetail Usage reference document.
Machines with a Blank Platter
Blank platters have a no drill zone [1] of  Ø7.25 in. and ↧1.75 in. for custom workholding on these platters.
Machines sold with a blank platter also have the option of purchasing the Haas air vise.
To install the vise the user will need to drill mounting holes outside the no drill zone [1].  Home the B & C-Axis and drill using the hole pattern that follows:
  • 100mm Air Vise – 4x ½-13 at 220mm [2] x 126mm [3] (on center)
  • 150mm Air Vise – 4x ½-13 at 270mm [2] x 252mm [3] (on center)
Use the brake bleed access hole for reference [4].
NOTE: Pictured is a UMC-500 blank platter but the no drill zone and Haas air vise hole pattern will be the same throughout all UMC models.
Electrical Diagrams
