    14. Постсоветский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
      • Drill/ Tap/ Mill Series
      • Robot Packages
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
      • Haas-Tooling-Home-TEST
      • VF-2SS
      • 05-0258
      • 08-1760
      • 08-1760
      • 08-1761
      Mill Toolholding Mill Workholding Tombstones Manual Chucks For Milling Mill Tooling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Broaching Tool Presetter & Heat Shrinkers Tooling Accessories Deburring & Abrasives Package Kits Apparel & Accessories Tool Storage Measuring & Inspection Winner's Circle
      • Drill Chucks
      • Pull Studs
      • Mill Toolholding Kits
      • Fixed Jaw Vises
      • Mill Vise Jaws
      • Workholding Accessories
      • Burrs
      • Cut-Off Tooling
      • Grooving Tools
      • Small ID Grooving & Threading Tools
      • Threading Toolholders
      • Boring Bars
      • OD Toolholders
      • Haas Notch Groove & Thread Inserts
      • Haas Notch Groove & Thread Toolholders
      • TL & CL Toolholding
      • BOT Toolholding
      • BMT Toolholding
      • Live Toolholding
      • Reduction Sleeves
      • VDI Toolholding
      • Spindle Liners
      • Lathe Collet Chucks
      • Lathe Boring Rings
      • ER Collets
      • Straight Shank Keyless Drill Chucks
      • Broaching Toolholders
      • Spindle Taper Cleaner
      • CNC Clearing Fans
      • Lathe Tooling Kits
      • Test Bars
      • Inspection Kits
      • Tool Setting Measuring Gauges
      FINANCING & OPEN TERMS FINANCING & OPEN TERMS
    14. Постсоветский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
Wired Probe System - Troubleshooting Guide
Service Home Wired Probe System - Troubleshooting Guide
Recently Updated Last updated: 04/06/2021
Jump to Section 1. Introduction 2. Work Probe Operation 3. Tool Probe Operation 4. OMI Operation 5. Symptom Table 6. Batteries 7. Interference 8. Macros 9. Surface Not Found 10. Settings 11. Calibration Back to Top
  1. OMP40 work probe: A spindle-mounted wireless probe that communicates with an optical interface.
  2. Work probe stylus: The part of the work probe that touches parts during measurement.
  3. Tool probe stylus: The part of the tool probe that tools touch during measurement. Tools touch the top and side of the stylus when the probe measures tool length and diameter.
  4. TS27R tool probe: The table-mounted TS27R has no batteries or optical interface. This is a wired probe.
  5. Tool probe cable: This cable carries signals from the tool probe to the CNC control.
  6. OMI Optical Machine Interface: The wireless interface for the OMP40 work probe. The OMI uses infrared light to communicate with the CNC control and switch the probe on or off.
  7. OMI cable: This cable connects the OMI to the CNC control.
Work probes for Wireless Probe System (WIPS) do not work in the wired probe systems (VQCPS).
  • The VCQPS work probe (P/N 60-0024) has a square Haas logo.
  • The WIPS work probe (P/N 60-0050) has a round Haas logo.
To power on the work probe, enter this program in MDI:
M53;
G04 P2.;
Push [CYCLE START].
The LEDs on the work probe flash green when the probe is powered on and ready for use. When the probe stylus is touched, a “beep” sound is made by the CNC control. The LEDs on the work probe flash red each time the stylus is touched.
To power off the work probe, enter this code in MDI:
M63;
To power on the wired tool probe, enter this program in MDI:
M52;
Push [CYCLE START].
When the stylus on the tool probe is touched, the CNC control makes a "beep" sound.
The tool probe does not have any LEDs.
To power off the wired tool probe, enter this program in MDI:
M62;
OMI Operation
[1] CNC control is powered on. The probe is not in use.
[2] M53 commanded. The OMI is sending a start signal to the work probe to power it on or power it off.
[3] The work probe is powered on and ready for use.
[4] The stylus has been touched. The OMI is sending a skip signal to the CNC control.
Alarm 1086 PATH OBSTRUCTED  Protected Positioning Cycle only. Clear the obstruction and start again from a safe position.
Alarm 1088 NO FEED RATE Protected Positioning Cycle only. Insert the F code input and start again from a safe position. Recommended protected positioning feed rate is 120 in/min.
Alarm 1089 NO TOOL LENGTH ACTIVE G43 or G44 is not active before the cycle is called. Edit the program and start again from a safe position.
Alarm 1091 FORMAT ERROR  Inputs are mixed, missing, or incorrectly formatted. Edit the program and start again from a safe position.
Alarm 1092 PROBE OPEN/UNEXPECTED SURFACE FOUND
Interference from the work lights. Adjust the work lights
Settings in the work probe are not correct. Correct the settings.
The surface of the part was not found. Edit the program.
Occurs if the probe is already triggered before a move or triggered while positioning the probe or tool. Clear faults and restart from safe position, check if chips are trapped around probe eyelids
Alarm 1093 PROBE FAIL/SURFACE NOT FOUND Interference from the work lights. Adjust the work lights
Alarm 1099 BROKEN TOOL This alarm occurs if a tool is out of user defined tolerance. Replace defective tool and establish correct tool offset value.
Alarm 1101 PROBE STARTUP FAILURE. Bad Batteries. Replace the batteries.
The macros are corrupted. Reload the macros
Settings in the work probe are not correct Correct the settings
During probe start-up, the spindle must reach a speed of 500 RPM. Check that the spindle override is not active. Possible faulty probe.
The tool probe does not beep/activate. The macros are corrupted. Reload the macros
The OMI LEDs do not turn green. The macros are corrupted. Reload the macros
Incorrect measurements. The probe is not calibrated. Calibrate the probe.
Batteries
Corrective Action:
Refer to Wireless Intuitive Probe System - WIPS - Troubleshooting Guide
Interference
Corrective Action:
Macros
Corrective Action:
The wired probe system uses Renishaw VQCPS macro version 1.9.
After you load this program file into the CNC control, make sure Setting 26, 9xxx PROGS EDIT LOCK, is set to 1. This prevents all of the Macro programs from being edited or deleted.
Surface Not Found
Corrective Action:
Settings
Corrective Action:
A procedure to verify the probe settings is included in the Renishaw Probes Installation guide. Refer to Mill - Renishaw Probes - Installation.
 Note: Do not touch the stylus when you install the batteries. This can change the settings.
To change the probe settings you move the stylus in a specified order. Refer to the illustration to see the specified order.
The Illustration shows these symbols: The symbols tells you this: This gives this result:
A red arrow that points to the right. Move and hold the stylus for less than (4) seconds. Selects the next option within a group.
A green arrow that points down. Move and hold the stylus for more than (4) seconds. Moves from one group to another.
A white arrow that points down. Do not touch the stylus for (20) seconds or more. Exits the set up.
Calibration
Corrective Action:
The probes need to be calibrated anytime a stylus has been replaced, the table probe has been moved, or if the CNC control generates alarms during probe routines. Follow the procedure for calibrating the Table Probe and the Spindle Probe. Refer to Mill - Probing with VQC Templates.
This procedure includes instructions for calibrating the probes. The probes must be calibrated in this order:
  1. Table Probe
  2. Spindle Probe Length
  3. Spindle Probe Diameter
FIND DISTRIBUTOR
  • Twitter
© 2023 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
