40-Taper - Belt/Gearbox Drive - Spindle - Replacement - AD0114
Service Home How To Procedures 40-Taper - Belt/Gearbox Drive - Spindle - Replacement - AD0114
Recently Updated Last updated: 06/07/2022
40 Taper - Belt/Gearbox Drive - Spindle - Replacement
AD0114
Applies to machines built from: January, 1989
- Jump to Section - 1. Removal (3 steps) 2. Installation (3 steps) Back to Top
Removal
Remove the spindle-head cover panels.
Change Parameter 76, LOW AIR DELAY, to 999999999 to override the low air pressure warning.
Close the primary air valve. This stops the air supply to the machine.
Tools Required:
  • Oil Pan
  • 6" x 6" x 6" (152 mm x 152 mm x 152 mm) wooden or aluminum block
If the machine has through-spindle coolant (TSC), disconnect the TSC hose from the TSC check valve.
Remove the TRP assembly [1].
If the machine has a mid-belt shield, remove it.
Remove the screws [2] for the motor mount.
 Note: If necessary, remove the TSC check-valve assembly to get access to the motor mount screws.
Move the motor assembly forward a small distance to release the tension on the drive belts [3].
Remove the drive belts.
Disconnect the oil line.
Remove the 90-degree fitting from the spindle lubrication port [1].
Install a 1/8" NPT plug [2] into the oil fitting port on the spindle. Install the plug flush or below flush with the surface of the spindle.
 Note: Grease Pack machines equipped with positive air pressure:
The replacement grease pack spindle may have a cap in which the threads for the oil plug has been removed.  The cap on grease pack spindles no longer is cross drilled and tapped.
If you recieve a grease pack spindle with a cap like this, remove the positive air system from the machine.  Refer to: Grease Pack Spindle  - Positive Air Pressure - Removal.
Put an oil pan [3] and a block of wood [4] on the table to catch oil leaks.
Loosen the (6) spindle screws [1] (2) turns.
Install the protective cap [2] over the spindle nose. The protective cap prevents damage to the spindle when it touches the table.
Jog the Z Axis in the negative (-) direction until the spindle touches the pan.
Remove the (6) spindle screws.
Jog the Z Axis in the positive (+) direction until the spindle head clears the spindle.
Remove the shims [5].
Clean and stone the surfaces where the spindle flange [1] and the spindle casting [2] touch.
Turn the spindle until the oil fitting port points to the front of the machine.
Slowly jog the Z Axis in the negative (-) direction over the spindle.
When the spindle is fully into the spindle housing, do these steps:
  • Remove the 1/8" NPT plug [1] from the oil fitting port on the spindle.
  • Install the 90° spindle lubrication fitting [2] as shown.
  • Connect the spindle lubrication tube.
  • Turn the spindle to align it with the tapped holes in the casting.
  • Install the (6) spindle screws [3].
  • Torque the screws. Refer to Haas Fastener Torque Specifications.Use the value for iron.
Install the drive belts [1]. Do not tighten the belts.
Install the mid belt shield, if applicable.
Jog the Z Axis to the middle of travel.
Do the spindle sweep procedure. Refer to VMC - Spindle - Alignment ("Spindle Sweep").
Insert and hand-tighten the motor-mount screws [2].
Tension the belt. Refer to VMC - Drive Belt Tension - Gates Sonic Meter - Instructions.
Torque the motor-mount screws. Refer to Haas Fastener Torque Specifications. Use the value for iron.
Install the tool release piston (TRP) assembly [3]. Hand-tighten the screws.
If the machine has through-spindle coolant (TSC), connect the TSC hose to the top of the TRP.
 Note: Do not add oil to the spindle casting, even if it had oil before.
Change Parameter 76, LOW AIR DELAY, to its initial value.
Adjust the Tool Release Piston: VMC - 20/30/40-Taper- TRP - Proximity Sensor - Adjustment.
Set Parameter 64:
  • For a Side-Mount Tool Changer, refer to: VMC - Side-Mount Tool Changer - Set Parameter 64 - Z-Axis Tool Change Offset.
  • For an Umbrella Tool Changer, refer to: Umbrella Tool Changer - Set Parameter 64 - Z-Axis Tool Change Offset.
Set Parameter 257:
  • For a Side-Mount Tool Changer, refer to Side-Mount Tool Changer - Spindle Orientation Offset - Parameter 257.
  • For an Umbrella Tool Changer, refer to Umbrella Tool Changer - Spindle Orientation Offset - Parameter 257.
Run the spindle break-in program: Spindle - Break-in Programs - Lathe and Mill
