50-Taper - Tool Release Piston - Subplate - Modification - AD0341
Service Home How To Procedures 50-Taper - Tool Release Piston - Subplate - Modification - AD0341
Recently Updated Last updated: 11/30/2018
AD0341
Applies to machines built from: June, 2012
- Jump to Section - 1. Introduction 2. Subplate Modification (3 steps) Back to Top
The 50-taper TRP has a steel subplate with (4) shoulder bolts. The shoulder-bolt holes on the subplate must be reamed to prevent damage to the TSC extension tube. This procedure tells you how to ream these shoulder-bolt holes.
  1. 50-Taper TRP Subplate
KIT PN: 93-9080, SRVC KIT EX-TUBE, 50T, UNION NOT/INCL. QTY: 1
Tools Required: Spindle Lock Tool (T-2080), 16mm reamer bit, Red-I Grease, Mobil CM-P Grease
Refer to 50-Taper - Tool Release Piston - Replacement - VMC, HMC for removal and installation instructions for the TRP.
Once the TRP is removed, use the 16 mm reamer bit [1] to make the (4) shoulder bolt holes [2] larger.
Remove the carbide shaft [2] from the removed extension-tube assembly [1].
Apply Red-I grease to the o-ring on the shaft [2].
Install the carbide shaft [2] onto the replacement extension-tube assembly [3]. Turn the carbide shaft counterclockwise to tighten it.
Refer to 50-Taper - Tool Release Piston - Replacement - VMC, HMC for TRP installation instructions.
Once the TRP is installed, connect all the cables and air hoses to the TRP, the TRP bracket, and to the bearingless TSC union.
Remove the spindle lock tool (T-2080) and NCE ring tool (T-0078).
If necessary, connect the spindle fan cable.
Turn the machine air supply on and examine all of the air hoses for leaks.
Remove the lockout tag.
Power on the machine.
Push the Tool Release Button to make sure that the TRP operates correctly.
Install the spindle head covers.
Do the VMC - 50-Taper - Tool-Release Piston (TRP) - Height Adjustment.
