Automatic Software Update Feature - NGC
Service Home How To Procedures Automatic Software Update Feature - NGC
Recently Updated Last updated: 02/02/2021
Automatic Software Update - How To Video
Starting with software version 100.18.000.1026 the control has the ability to download, schedule and update the control software. This feature allows the machine to have the latest software updates. If the machine software version is lower than 100.18.000.1026 contact your local Haas Factory Outlet to have it upgraded.
Machine Requirements:
  • Internet Connection - The machine requires a connection to the Internet via the standard Ethernet connection or the optional Wi-Fi connection.
  • MyHaas Account - The machine requires to be registered in MyHaas.
    Note: If the status bar shows the MyHaas icon, the machine is already connected to MyHaas. If you need help setting up a MyHaas account go MyHaas Machine Registration.
  • Download Storage Space - A USB device with a minimum of 4GB capacity is required for machines that have an older processor PCB.  See installation section below for more details.
  • Bill Time:  Machine must be unlocked or have at least 10 days left on your Bill Time.   If the machine has less than 10 days, contact your local HFO to get an extension code.
Note: Contact Haas Service before performing this procedure to activate the remote software update feature. This will need to be activated every time the procedure is done.
Automatic Software Update - Setup
Verify that machine is connected to the network [1] and registered to MyHaas [2].
Press [SETTING] and go to the "Network" tab and navigate to "MyHaas" tab.  Make sure the Register and Connected are set to "On" [3].
IMPORTANT: Make sure the Date and Time are set correctly.
Press [DIAGNOSTIC]. Go to the Maintenance tab and cursor to the Software Update tab.
Press [E-STOP].
Press [F3] to check for updates.
Note:  The message "No Updates Found" is normal if you have the latest software.   If you don't have the latest software then contact your local Haas Factory Outlet to have your machine activated for Automatic Software Updates.
 Note:  If message "Insufficient Disk Space"  install a USB device into the processor PCB see the next step.
Press [F3] to start the Software Download.
Note: During the a software update download, the machine power savings features will be temporary disabled. The machine power saving features will be restored once download is paused, canceled, or completed.
Note:  The machine control will also pause the software download, if the spindle is turning or if there is axis motion. Once the machine is stopped the control will resume the download process.
Perform this step ONLY if you got a "Insufficient Disk Space" message during the check for update process.
Turn off the main circuit breaker.
Remove the top left metal cover.
Connect the USB device [1] to the J8 port [2] on the Main Control PCB.
Install the metal cover.
Turn on the main circuit breaker.
Power on the machine.
Press [E-STOP].
Press [F4] to start the automatic update process.
During this process the machine will cycle power.
 Note: The machine will activate after it reconnects to MyHaas server.
Pull the [E-STOP]  and press [RESET] to reset all the alarms.
Verify that the software version is updated.
Note: It is normal for alarm 9915 IO BOARD CONFIGURATION CRC MISMATCH to be generated,  the alarm should clear when the E-stop button is depressed and the alarms are reset .
Note: Generate an error report [SHIFT + F3] and  contact your Local Haas Factory Outlet if you get the following:
Software Mismatch Alarms
Initialized Error Alarms
Unresetable Alarms
Software Update - Setup Screen Options
  1. Update Check Mode: This setting sets when the control will check for a software update. The choices are:
    Disabled - the control will not check for software updates.
    Power Up - the control will check for a software update at power up.
    Scheduled - the control will check for a software update, depending on what the Schedule Check Interval (days) is set to.
    Scheduled & Power Up - the control will check for a software update at power up and also when is scheduled.
  2. Automatic Update: This setting sets what the control will do if there is an updated software version. The choices are:
    Disabled - The control will not download or update the software automatically.
    Download - When there is a software update available the control will download the software.
    Download and Update - When there is a software update available the control will download and update the software automatically.
  3. Schedule Check Interval (days): This setting allows you to set the interval (in days) when the control will check if there is a software update available.
Software Update - Status Icons
The status bar [1] in the top left of the screen will show the software update status:
  1. A software update is available.
  2. The software update is downloading.
  3. The software updated is paused.
  4. The software update failed.
  5. The software update download is complete.
