CM-1 36 Pocket Tool Changer - Door Spring Replacement - AD0678
Service Home How To Procedures CM-1 36 Pocket Tool Changer - Door Spring Replacement - AD0678
Recently Updated Last updated: 04/19/2023
AD0678
- Jump to Section - 1. Introduction 2. Spring Removal (2 steps) 3. Spring Installation (2 steps) Back to Top
This procedure tells you how to replace the 36 pocket tool changer's door spring on CM-1 machines.
This Document Applies to the following Service Kits:
  • 93-3750 UMB 36 PCKT ISO20 SLIDE PANL SPRING KIT
Spring Removal
NOTE: This procedure can be done with the tool changer still mounted. It is not shown in the illustration for clarity.
Jog the spindle head to the top of travel in order to make the umbrella tool changer easily accessible.
Remove all the tools from the tool changer.
Put a piece of tape on the carousel at Pocket 1 in order to note orientation.
Remove the number ring [1] on the bottom face of the umbrella tool changer.
Remove 3 of the 4 screws securing the sliding panel cover [1] to the carousel. Loosen the 4th screw to allow movement to the sliding panel cover [1].
Remove the inner set screw connecting the door spring [3] to the carousel.
Pull the sliding panel [2] and door spring [3] out through the front of the sliding panel cover  [1]. Disregard them.
Tighten the 4th screw to secure the sliding panel cover [1].
Index the next pocket and repeat this step to each pocket.
Spring Installation
Loosen the 4th screw to allow movement for the sliding panel cover [1].
Apply Mobil SHC-460 grease to the new door spring [3].
Install the inner set screw [2] connecting the door spring [3] to the carousel.
NOTE: Make sure the full dog of the set screw [2] fits snug in the inner diameter of the door spring [3].
Install the outer set screw [4] connecting the sliding panel [5] to the door spring [3].
Install 3 of the 4 screws securing the sliding panel cover  [1] to the carousel. Tighten the remaining 4th screw.
Make sure the sliding panel [5] slides freely.
Install the number ring [1] on the bottom face of the umbrella tool changer.
NOTE: Align the number ring with tapped pocket 1. Remove the tape once number ring [1] is installed.
Insert all the tools into the tool changer.
