  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
      • Compact Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet-Pool Systems
      • Haas Bar Feeder
      • Models
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
  • Service
  • Videos
      Mill Toolholding Mill Workholding Milling Lathe Tooling Lathe Toolholding Lathe Workholding ER Collets & Chucks Holemaking Threading Tool Management Tooling Accessories Package Kits Apparel & Accessories Storage & Handling Measuring & Inspection
    • Mill Toolholding Shop All
      • Drill Chucks
      • Pull Studs
      • Mill Toolholding Kits
    • Mill Workholding Shop All
      • Vises
      • Mill Vise Jaws
      • Workholding Accessories
    • Milling Shop All
      • Indexable Milling Kits
      • Complete Indexable End Mill Kits
      • Burrs
    • Lathe Tooling Shop All
      • Cut-Off Tooling
      • Grooving Tools
      • Small ID Grooving & Threading Tools
      • Threading Toolholders
      • ID Toolholders
      • OD Toolholders
      • Haas Notch Groove and Thread Inserts
      • Haas Notch Groove and Thread Toolholders
      • Broaching Toolholders
    • Lathe Toolholding Shop All
      • TL & CL Toolholding
      • BOT Toolholding
      • BMT Toolholding
      • Live Toolholding
      • Reduction Sleeves
      • VDI Toolholding
    • Lathe Workholding Shop All
      • Spindle Liners
      • Lathe Collet Chucks
    • ER Collets & Chucks Shop All
      • ER Collets
      • Tap Collets
      • Straight Shank Keyless Drill Chucks
    • Holemaking Shop All
    • Threading Shop All
    • Tool Management Shop All
    • Tooling Accessories Shop All
      • Spindle Taper Cleaner
      • CNC Clearing Fans
    • Package Kits Shop All
    • Apparel & Accessories Shop All
    • Storage & Handling Shop All
    • Measuring & Inspection Shop All
      • 7-Piece Measuring Kit
      • 3D Sensor Kit, Inch, CT40
      • 3D Sensor Kit, Metric, SK40/DIN
      • 3D Sensor Kit, Metric, BT40
      • 3D Sensor Kit, Inch, HSK63A
      • 3D Sensor Kit, Metric, HSK63A
      • 3D Sensor, Inch
      • 3D Sensor, Metric
      • WIPS Stylus, 3-Pack
      • WIPS Replacement Stylus
      • Spindle Test Bar
      • Coolant Refractometer
      • Clamp Force Gauge
      NEW PRODUCTS NEW PRODUCTS
      OPEN TERMS OPEN TERMS
      FINANCING FINANCING
    • Automatic Pallet Changer Shop All
    • Lathe Turret Shop All
    • Tool Changer Shop All
    • Chip Management Shop All
    • Coolant Shop All
    • Counterbalance Shop All
    • Electrical Cabinet Shop All
    • Enclosure Shop All
    • Hydraulics Shop All
    • Lubrication Shop All
    • Maintenance Shop All
    • Pendant Shop All
    • Probing Shop All
    • Rotary Shop All
    • Spindles Shop All
    • Tailstock Shop All
My Cart
Find A Dealer
    4. Español - Méjico
    14. Русский
    15. Türkçe
    16. 中文
    17. Suomi
    18. Norsk
    19. الإنجليزية
    20. български
    21. Hrvatski
    22. Ελληνικά
    23. Română
    24. Slovenský
    25. Slovenščina
    26. 한국어
    27. 日本語
Search
Standard Coolant - Supplemental Washdown Hose - Installation - AD0181
Service Home How To Procedures Standard Coolant - Supplemental Washdown Hose - Installation - AD0181
Recently Updated Last updated: 06/07/2022
AD0181
Applies to machines built from: January 1989
- Jump to Section - 1. Introduction 2. Installation (4 steps) Back to Top
The Supplemental Washdown-Hose features include:
  • The ability to easily clean chips from hard-to-reach areas on large machines.
  • Easy installation in a location that is convenient for the customer's application.
You can install the Supplemental Washdown-Hose on all Haas machines with a spare garden-hose fitting on the Coolant Manifold Assembly.
For all other machines you must install a garden-hose fitting to the coolant pump system. The kit does not include the parts to install these fittings.
KIT PN: 93-2273, COOLANT WASHGUN KIT
Connect the HOSE [B] to a garden-hose fitting [1or 2] on the coolant system.
A common location of an available garden-hose fitting is on the coolant manifold assembly [1] or the cast coolant filter [2].
 Note: If the machine does not have an available garden-hose fitting, install a garden-hose fitting onto the coolant pump system. The kit does not include the parts to install these fittings.
Find a location on the machine to install the HOLSTER [D] for the washdown gun.
 Note: The hose is 25 ft (7.6 m) long. Be sure to stay in that limit.
Hold the HOLSTER [D] at that location.
Make a mark at the (3) screw locations [2]. Use a punch or a pen.
Use the illustration in Step 3 to find the location of the drain hole.
Measure the dimensions from the hole locations in Step 2.
Make a mark for the center [1] of the drain hole. The diameter of the drain hole is 1.0" (2.5 cm).
Use a hole saw to cut the drain hole.
Hold the holster gasket onto the enclosure. Attach the HOLSTER [D] to the enclosure.
Use the (3) SCREWS, PPHS [E].
 Note: If you damage the sheet metal, use the (3) SCREWS, FBHCS [C] and the (3) NUTS [F]. Drill (3) 0.266" (6.75 mm) holes.
Attach the NOZZLE [A] to the end of the HOSE [B].
Put the NOZZLE [A] in the HOLSTER [D].
Press [COOLANT] to start the coolant pump.
Examine all of the fittings for leaks.
FIND DISTRIBUTOR
  • Twitter
© 2022 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
