K1 Contactor Replacement - AD0254
Service Home How To Procedures K1 Contactor - Replacement
Recently Updated Last updated: 09/12/2025
AD0254
Revision A - 09/2025
- Jump to Section - 1. Introduction 2. Electrical Safety 3. K1 Contactor - Breaker Mount Type - Replacement (3 steps) 4. K1 Contactor Breaker Mount Type (6 steps) 5. K1 Contactor -Chassis Plate Mount Type - Replacement (5 steps) Back to Top
This procedure tells you how to replace the K-1 contactor.
The new contactor may mount to the back of the circuit breaker assembly [1]. This type of circuit breaker has quick-disconnect terminals. The new contactor may mount to the chassis plate [2] of the control. This type of contactor does not have quick-disconnect terminals. Both types of contactors operate the same.
This document applies to these parts:
PN: 93-2311, IEC CONTACTOR ELECTRICAL KIT
Electrical Safety
 DANGER: Working with the electrical services required for CNC machines is extremely hazardous and can result in serious injury or death.
Before connecting line wires to the CNC:
  • Turn off all power to the machine at the source.
  • Perform a Lockout-Tagout (LOTO) procedure to ensure the power remains off during service.
  • Verify that power has been disconnected by using an AC voltage detector on all incoming lines.
If you are uncertain about how to safely disconnect power or perform LOTO procedures:
  • Do not proceed.
  • Contact qualified personnel or obtain appropriate assistance before continuing.
Failure to follow these precautions may result in electrical shock, equipment damage, or fatal injury.
 Danger: Before beginning any work inside the control cabinet, verify that the High Voltage indicator light on the 320V Power Supply / Vector Drive has been off for a minimum of five (5) minutes. This waiting period ensures that residual voltage has dissipated and reduces the risk of electric shock.
Certain service procedures involve high-risk electrical components and may pose serious injury or fatality hazards. Technicians must not attempt any procedure unless they have a complete understanding of the steps involved and the associated risks.
If there is any uncertainty regarding a procedure, contact your Haas Factory Outlet (HFO) to arrange for a qualified service technician.
Do this procedure to install a contactor which mounts to the control chassis plate. This type of contactor replaces the type that mounts to the back of the circuit breaker. This kind of contactor does not have quick-disconnect terminals.
Push [POWER OFF].
Danger: Disconnect the main power supply to the machine.
Danger: After you disconnect the main power supply, wait for the LEDs on the early power-fault detection module (EPFDM) and the vector drive to go off fully. This may take 20 or more minutes.
Disconnect the electrical supply wires [1] to the circuit breaker assembly [2]. Record the color sequence of the wires.
Remove the cover from the PSUP PCB. This makes it easier to remove the circuit breaker assembly.
Disconnect the (3) transformer cables [3] at the transformer.
Remove the circuit breaker assembly.
Remove the contactor [4] from the circuit breaker assembly.
Move the cables from the used contactor to the replacement contactor [1].
Attach the replacement contactor to the rear of the circuit breaker assembly [3].
Connect the contactor cables [4].
Install the main circuit breaker assembly to the side of the cabinet.
Connect the transformer cables [5] from the contactor to the transformer.
Connect the electrical supply wires [2] to the circuit breaker.
Push [POWER OFF].
Remove the circuit breaker assembly [2].
Remove the contactor [5] from the circuit breaker.
Disconnect the 71-73 cable [4] at the power supply (PSUP) PCB.
Disconnect the auto/off cable [6] at the I/O PCB.
Connect these cables:
  • Circuit breaker cables [1] to the ports that have the label "1 L1", "3 L2", and "5 L3."
  • CABLE 71/72/73 POWER K1 TO PS [B] to the ports that have the label "1 L1", "3 L2", and "5 L3"
  • CABLE 170 AUX/COIL CABLE leads that have the label "COIL" [A-1]:
    • Red to the port that has the label "A1"
    • Black to the port that has the label "A2"
  • CABLE 170 AUX/COIL CABLE leads that have the label "AUX" [A-13]:
    • red to the port that has the label "13"
    • black to the port that has the label "14"
  • transformer cables [3] to the ports that have the label "2 T1/4 T2/6 T3"
Note: Different type contactors are used on different size machines. This image shows a 40Amp contactor that is used on smaller machines. See the image below for the different contactors that are used.
Attach the replacement contactor [4] to the CONTROL CONTACTOR ADAPTER PLATE [C]. Attach the adapter plate to the chassis plate of the control cabinet.
This image shows the different size contactors that are used on machines:
  1. 40Amp Contactor
  2. 60Amp Contactor
  3. 75Amp Contactor
Note: These contactors have different positions for A1, A2, 13, and 14 terminals.
For example, you can see how the A1 [4] terminal is located on the front right of the 40Amp contactor [1], but the A1 terminal is located behind the L1 terminal on the 60Amp contactor.
Similarly the A2 terminal [5] is on the front right of the 40Amp contactor but the A2 terminal [5] is behind the L3 terminal on the 60Amp.
Make sure you make all the connections according to the labels on the contactor you are installing.
Connect the contactor-circuit breaker cables [3] to the circuit breaker [2].
Install the main circuit breaker to the side of the cabinet.
Connect the transformer cables [4] from the contactor to the transformer.
Connect the electrical supply cables [1] to the circuit breaker in the order you removed them.
Connect the cables in the kit to the contactor. Read the labels on the cables to make these connections:
  • Cable 71/72/73.
    • Classic Control with I/O PCB version S
      • PSUP PCB P25 [1]
      • PSUP PCB P23 [2]
    • Next Generation Control
      • PSUP PCB P19 [3]
      • PSUP PCB P14 [4]
  • Cable 170
    • I/O PCB P42 [5]
Do this procedure to install a contactor which mounts to the control chassis plate. This kind of contactor does not have quick-disconnect terminals.
Push POWER OFF.
Disconnect the (3) contactor/circuit breaker cables [3] from the circuit breaker.
Disconnect the (3) transformer cables [5] at the transformer.
Remove the contactor bracket [4] from the control chassis plate.
Remove the contactor from the contactor bracket.
Attach the replacement contactor [1] to the adapter plate [2].
  1. 40Amp Contactor
  2. 60Amp Contactor
  3. 75Amp Contactor
Connect the contactor/circuit breaker cables [3] to the circuit breaker [2].
