Pallet Changer - Crash Recovery - MDC
Service Home How To Procedures Pallet Changer - Crash Recovery - MDC
Recently Updated Last updated: 11/30/2018
- Jump to Section - 1. MDC - Pallet Changer - Crash Recovery Back to Top
  1. Push [EMERGENCY STOP].
  2. Change Setting 7 PARAMETER LOCK to OFF.
  3. Push [ALARM MESGS].
  4. Type "DEBUG" push [ENTER].
  5. Set Parameter 209 bit 28 NO ZERO CLAMP to 1.
  6. Change Parameter 151 INVIS AXIS to 0.
  7. Change Parameter 170 GRID OFFSET to 0.
  8. Change Parameter 213 TOOL CHANGE OFFSET to 0.
  9. Release [EMERGENCY STOP] and push [RESET].
  10. Zero return the B Axis.
  11. If machine has a zero return margin alarm, type "GRID A" push [ENTER]. "Grid Offset Done" message will display.
  12. Manually rotate the pallet changer to the clamp position or jog the B Axis to line up the pallet to the receiver.
  13. Lower the air pressure until the pallet changer drops into position.
  14. Press [ALARM MESGS] , type "DEBUG", then push [WRITE ENTER].
  15. Push [POSIT], then navigate to the POS-RAW DAT page.
  16. Get the value of B actual (ignore any minus sign or decimal points).  Enter this value into Parameter 213.
  17. Raise the air pressure to 90 psi (62 bar).
  18. Change Parameter 209 NO ZERO CLAMP to 0.
  19. Zero return the B Axis.
  20. Make sure the pallet clamps smoothly. Check B Fuse Level on the POS-RAW DAT page.  (Should be below 50) Adjust Parameter 213 if needed.
  21. If the pallet changer is clamping normally, change Parameter 151 INVIS AXIS back to 1.
  22. Power cycle the machine.
  23. Zero return all axes.
  24. Enter the following test program in MDI mode. Run the program to verify the function of the pallet changer.
    • M50 P1
    • G04 P2.
    • M50 P2
    • G04 P2.
    • M99
 Note: On machines that have a single Mocon PCB, the APC is on the "B"axis. On machines that have two Mocon PCBs, the APC on the "W" axis.
