VF Medium - Panel Replacement - AD0607
Service Home How To Procedures VF Medium - Panel Replacement - AD0607
Recently Updated Last updated: 05/11/2022
AD0607
- Jump to Section - 1. Introduction 2. Removal (3 steps) 3. Replacement (2 steps) 4. Cable Conduit Opening (2 steps) Back to Top
This procedure outlines how to do a panel replacement on a VF-Medium machine.
This procedure applies to the following service kits:
  • 93-3490: ENCL PANL SIDE RT VF-3 REPLACEMENT
  • 93-3491: ENCL PANL SIDE RT VF-3YT REPLACEMENT
  • 93-3492: ENCL PANL SIDE RT VF-5 REPLACEMENT
  • 93-3493: ENCL PANL BACK RT VF-3/YT 40T REPLACEMNT
  • 93-3494: ENCL PANL BACK RT VF-3YT/50 REPLACEMENT
  • 93-3495: ENCL PANL BACK RT VF-5/40 REPLACEMENT
  • 93-3496: ENCL PANL BACK RT VF-5/50 REPLACEMENT
Removal
Follow this step when replacing the side panel
To remove the old side panel [1], unscrew all the bolts [2] holding it to the machine.
Once the old side panel is removed, the window must be removed from it.
Apply heat to the window bracket/handle [1] and slide the window [2] out of the panel.
Note: Keep the window and its bracket/handle as they will be reused on the new panel.
Follow this step for replacing the back panel
To remove the back panel first remove the lube panel [1] to gain more access.
Once the lube panel is removed, remove the back panel [2] by unscrewing all the bolts [3] holding it to the machine.
Replacement
Attach the new side panel [1] reusing the old bolts.
Once the panel is attached, place the window bracket/handle [2] on the lip of the window cut out inside the machine and slide the window [3] back into the panel and bracket as shown on the right side of the image.
Use sikaflex to attach the window [3] to the bracket/handle [2].
Follow this step when replacing the back panel
Attach the new back panel [1] reusing the bolts [2] from the old panel.
Once the panel is replaced, reattach the lube panel [3].
After replacing a panel, the cable conduit may need to be added to the top panel of the machine.
To do this, cut out a 4.5 inch [2] by 2.5 inch [1] opening 3 inches [4] from the right edge of the panel and 3 inches [3] from the top edge of the panel.
Drill a 5/16 inch hole 0.250 inches [5] from the bottom of the cut out and 0.625 inches [6] from the left side of the cut out.
Place the hole cover [7] from the kit to line it up with the drilled hole [8] and drill the remaing 3 holes [9].
If the cable conduit is not being used, attach the cover [1] using the provided hardware.
If the cable conduit is needed, attach the top [2] and bottom [3] brackets as shown using the provided hardware.
