      • Coating Thickness Gauges
      • Hardness Tester
      • Portable EDM
      • Rotary Workholding Kits
      • Parts Wash-Off Tools & Kits
30-Taper - 30K Spindle Motor Belt and Isolators - Replacement - AD0145
Service Home How To Procedures 30-Taper - 30K Spindle Motor Belt and Isolators - Replacement - AD0145
Recently Updated Last updated: 03/20/2025
AD0145
Applies to machines built from: January, 2011
- Jump to Section - 1. Introduction 2. Replacement (16 steps) Back to Top
This procedure tells you how to replace the spindle motor belt and the mounting isolators on VMC 30-Taper 30K spindle machines.
Tools Required:
  • Belt tension tool (P/N T-1488)
  • Gates Sonic tension meter 508c or 550
Parts Required:
  • Spindle motor belt service kit (P/N 93-2245)
  • Non-metallic spacer, 3/4" x 2" x 2" (19 x 25 x 25 mm)
Replacement
Press [POWER OFF].
Turn off, then Lockout/Tagout the main circuit breaker.
Turn off the air supply.
Remove the spindle head covers.
Disconnect the electrical cables from the tool release piston (TRP) assembly.
Disconnect the air hoses from the tool release piston (TRP) assembly.
Remove the (4) screws.
Remove the TRP from the head stock casting.
Remove the (4) screws and the (4) washers from the motor mounting plate.
Move the motor assembly forward.
Remove the belt from the motor assembly.
Examine the pulleys for wear or tooth damage. If the pulleys are damaged or worn, replace them.
Use a pry-bar to lift the motor assembly on the right-side of the head stock casting.
Put a non-metallic spacer, approx 3/4" thick (19 mm), between the head stock casting and the motor mounting plate.
 Caution: Make sure that the spindle motor assembly stays attached to the isolators on the left-side while you lift the right-side.
Put a 7/8" (22 mm) tool socket [1], or some other pushing rod, over the spacer [2].
Use the pry-bar to push the spacer out of the bottom of the motor mounting plate.
Remove the right-side isolators and spacers from the motor mounting plate.
Put the (2) spacers into the (2) white plastic isolators.
Insert the (2) plastic isolators and spacers under the (2) holes of the motor mounting plate.
 Note: Make sure that the plastic isolators and spacers are tightly inserted into the holes of the mounting plate.
Use the pry-bar to lift the motor mounting plate.
Remove the non-metallic 3/4" (19 mm) spacer.
Make sure the weight of the motor assembly rests completely on the (2) plastic isolators against the head stock casting and the motor mounting plate.
Insert the (2) black plastic isolators.
Use a pry-bar to lift the motor mounting plate assembly on the left-side of the head stock casting.
 Caution: Make sure that the spindle motor assembly stays attached on the isolators on the right-side while you lift the left-side.
Repeat Steps 6, 7, 8, and 9 on this side of the spindle motor.
Install the new belt over the pulleys.
Push the motor assembly toward the back of the machine to tighten the belt.
Align the (4) isolator assemblies with the holes on the head stock casting.
Install the (4) screws and (4) washers. Hand tighten the (4) screws.
Install the belt tension tool on the spindle casting.
Torque the (4) screws to approximately 5-10 ft-lb (7-14 Nm).
Turn the belt by hand to make sure the belt engages the pulleys.
13
Tighten the belt tension tool to increase the belt tension.
Belt tension meter settings:
Mass: 004.1 g/m
Width: 025.0 mm/R
Span: 0209 mm
Tension: 50-58 lbs (222-258 N)
Refer to VMC - Drive Belt Tension - Gates Sonic Meter - Instructions.
Torque the (4) motor mounting screws to 50 ft-lb (68 Nm).
Remove the belt tension tool.
Look at the tension meter again. If the meter reading has changed, loosen the screws and repeat the previous procedure. Do this until the tension is correct.
14
Install the the TRP assembly on the head stock casting.
Connect the electrical cables to the TRP assembly.
Connect the air hoses to the TRP assembly.
Turn on the air supply.
Remove the lockout tag.
Press [POWER ON].
 Caution: The spindle must have a tool holder when it operates higher than 15,000 RPM.
Install a tool holder in the spindle. Run spindle to 30,000 RPM. Do this to make sure that the belt stays near the center of the spindle pulley. The belt must not move up or down when you increase or decrease the spindle RPM.
Measure the belt tension. If necessary, adjust the tension again.
16
Install the spindle head covers.
