DT/DM - Rear-Lift Auger - Installation - AD0350
Service Home How To Procedures DT/DM - Rear-Lift Auger - Installation - AD0350
10.3 DT/DM - Rear Lift Auger - Installation
Recently Updated Last updated: 02/10/2025
DM-1/DT-1 - Rear-Lift Auger - Installation
AD0350
This procedure tells you how to install a rear-lift auger system.
Machine Compatibility
Do this procedure on a DM-1 or DT-1 that was made after August, 2016.
The machine must have a side chip-auger system installed. Refer to DM-1, DT-1 - Side Chip-Auger - Installation.
Tools Required
Floor jack, 2" x 4" x 24" (51 mm x 1 cm x 6 cm) wood
Push [POWER OFF].
Set the main circuit breaker to the OFF position.
Remove the control skirt [1].
If the machine has chip chute extensions [3], do these steps:
  • remove the V-flange clamps [2]
  • remove the chip chute extensions [3]
For all machines, do these steps:
  • remove the chip chutes [5]
  • remove the coolant guard [4]
  • discard the chip chutes [5], chip chute extensions [3], and coolant guard [4]
Disconnect each auger [2] from the coupler [1].
Remove the augers [3].
This makes the rear lift-auger installation easier.
Remove the used sealant from the base.
Install sealant tape on the base as shown.
Put a 2" x 4" x 24" (50 mm x 101 mm x 610 mm) block of wood [2] onto a floor jack [3].
Put the lift auger assembly [1] onto the wood block.
Caution: The lift-auger assembly is heavy. Get the aid of another person to lift the auger.
Use the jack to lift the assembly into position.
Attach the assembly to the base casting.
Remove the jack.
Attach the base [1] for the rear chip guard.
Insert the augers [2] into the drain holes.
Connect each auger [5] to the motor shaft [3] with a coupler [4].
Install the front auger-trough cover [1].
Install the rear auger-trough cover [2].
Put the auger cable [1] through the bottom of the control cabinet.
Connect the auger cable to the I/O PCB. P38 [2] for Classic Haas Control or P24 [3] for Next Generation Control.
Install the control skirt [1].
Attach the extension [4] to the chip chute [2].
Use the V-flange clamp [3].
Put the coolant tank [1] below the auger assembly.
Put the 18-gallon chip container [2] under the chip chute extension.
Connect the coolant hose [3].
Connect the coolant pump cable [4].
Set the main circuit breaker to the ON position.
Press [POWER ON].
Start the auger.
Make sure the auger motors operate correctly.
Start the coolant.
Make sure the auger system operates correctly.
Make sure the auger system has no coolant leaks.
