Fourth and Fifth Axis Drive - Installation - Mill - CHC
Service Home How To Procedures Fourth and Fifth Axis Drive - Installation - Mill - CHC
- Jump to Section - 1. Electrical Safety 2. Introduction 3. Fourth-Axis Installation (4 steps) 4. Fourth-Axis and Fifth-Axis Installation (13 steps) Back to Top
Recently Updated Last updated: 10/24/2025
AD0004
Revision A - 10/2025
Electrical Safety
 DANGER: Working with the electrical services required for CNC machines is extremely hazardous and can result in serious injury or death.
Before connecting line wires to the CNC:
  • Turn off all power to the machine at the source.
  • Perform a Lockout-Tagout (LOTO) procedure to ensure the power remains off during service.
  • Verify that power has been disconnected by using an AC voltage detector on all incoming lines.
If you are uncertain about how to safely disconnect power or perform LOTO procedures:
  • Do not proceed.
  • Contact qualified personnel or obtain appropriate assistance before continuing.
Failure to follow these precautions may result in electrical shock, equipment damage, or fatal injury.
 Danger: Before beginning any work inside the control cabinet, verify that the High Voltage indicator light on the 320V Power Supply / Vector Drive has been off for a minimum of five (5) minutes. This waiting period ensures that residual voltage has dissipated and reduces the risk of electric shock.
Certain service procedures involve high-risk electrical components and may pose serious injury or fatality hazards. Technicians must not attempt any procedure unless they have a complete understanding of the steps involved and the associated risks.
If there is any uncertainty regarding a procedure, contact your Haas Factory Outlet (HFO) to arrange for a qualified service technician.
This procedure tells you how to install these components on machines that have Classic Haas Control (CHC):
  1. Optional Fourth-Axis and Fifth-Axis Drive
  2. Rotary Scale Feedback
  3. Secondary Mocon PCB
  4. Expansion PCB
If you are installing a Fourth-Axis, only refer to the Fourth-Axis Installation section.
If you are installing Fourth-Axis and a Fifth-Axis at the same time, refer to the Fourth-Axis and Fifth-Axis Installation section.
Machine Compatibility:
  • Mill that has brushless servo amplifiers.
 Note: All machines must be geolocated by a service technician when a 5th axis upgrade is installed and activated.
Motion sensor support has been posted on HBC in HBC -> Service -> Utilities -> Documents and software -> 11_Geolocation & Motion Sensor.
Document Applies to these Parts:
Only one kit is necessary to complete the procedure.
  • 4AXBLMM: Use for a MM, TM, DT-1.
  • 93-4AXBL-OM: Use for an OM machine built after 10/02.
  • 93-0221A: Use for all other machines built on or before 10/02.
  • 93-1221B: Use for all other machines built after 10/02.
Push [POWER OFF].
Set the main circuit breaker to the OFF position.
Find the (2) plugs [1] for the A-Axis receptacles. The plugs are on the side of the control cabinet. Push the plugs out of the holes.
Install the 7-pin power connector [2] into the receptacle that is labeled A-AXIS POWER. Then, use the (4) screws to secure the plug.
Install the 28-pin encoder connector [3] in the receptacle with the A-AXIS ENCODER label. Then, use the (4) screws to secure the plug.
Remove the I/O PCB and Maincon cover.
The following step applies to 4th-axis drive cable PN 36-4034D.
Find the location on the amplifier bank that has the A Axis label. Install the amplifier for the fourth-axis drive at this location.
Connect the fourth-axis servo cable wires to the high-voltage terminals on the amplifier:
  • red to RED [1]
  • white to WHT [2]
  • black to BLK [3]
 Note: The cables have the labels A, B, and C. Make sure the labels are in the correct sequence.
Connect jumpers [4] from the fourth-axis drive to the nearest amplifier on each side:
  • Connect the black wire to -H.V.
  • Connect the red wire to +H.V.
  • Connect the shield wire to ground.
Put the cables in the cable tray.
Connect the 6-pin connector [1] on the A-Axis brake cable to P46 [2] on the I/O PCB.
Connect the 16-pin connector [4] on the encoder cable to P9 [3] on the Maincon PCB.
Connect the 10-pin connector [5] on the current command cable to the P5 connector [6] of the Maincon PCB.
Note: The image shows the 10-pin connector is being plugged into a stand alone Mocon where the P5 connector is horizontal. With machines with a Maincon/Mocon combination board, the P5 connector will be vertical.
Connect the 8-pin connector [8] on the current command cable to the amplifier [7].
Set the main circuit breaker to the ON position.
Push [POWER ON].
Refer to this procedure to enable the option Option Code Activation. Make sure the parameters are correct. Refer to Parameter Checker Program - Menu Option (7).
Refer to the Rotary - Installation procedure to install a TR, TRT, or T5C rotary unit on a Haas VMC.
Prerequisites:
 Note: Service Kit 93-5AXIS-SAO or 93-5AXIS-SS is for rotaries that have scales. Linear or rotary scales are available for mills with software version 18.00 or higher.
For these machines, a second Mocon PCB is necessary for an optional fifth-axis drive installation:
  1. VF-2SS/3SS/4SS/5SS/6SS
  2. SMM-2 with a side-mount tool changer (SMTC)
  3. DT-1/2
  4. MDC-500
  5. All EC models
Software requirements
  • Software version no higher than 18.28A.
If the machine has a higher software version, it must be downgraded to 18.24A. If the machine has a lower software version, it is recommended but not required to be upgraded to 18.24A.
Document Applies to These Parts:
One of these Fourth-Axis kits is necessary to complete the procedure:
One of these Fifth-Axis kits is necessary to complete the procedure:
  • 93-5AXIS-SS : Use for either a SS, EC1600, ES, or a SMM-2 with a SMTC.
  • 93-5AXBL-OM: Use for an OM machine built after 10/02.
  • 93-5AXIS-SAO : Use for a MM, TM, DT-1 and all other machines built after 10/02.
  • 93-5AXIS-SS: Use for all other machines built on or before 10/02.
Push [POWER OFF].
Find the plug [1] for the A-AXIS SCALE and B-AXIS SCALE receptacles. The plugs are on the side of the control cabinet. Pull the plugs out of the holes.
Connect the 28-pin connectors [2] from the rotary scale feedback cable to the A-AXIS SCALE and B-AXIS SCALE receptacles. Use the (8) 4-40 screws.
Remove the PSUP PCB cover.
Connect the 3-pin connector [3] of the A-AXIS rotary scale feedback cable to P34A [4] and the B-AXIS rotary scale feedback cable to P34B on the PSUP PCB.
Install the PSUP PSB cover.
Remove the Maincon PCB [2] cover.
Put a label on each cable to show its location for the installation. Disconnect the necessary cables. Remove the (5) standoffs [1]. Remove the Maincon PCB.
Find the (5) 1-1/4" standoffs [3] in the service kit. Install these standoffs onto the top of the (5) 1/2" standoffs [4] where the Maincon PCB was installed.
Remove the (6) screws from the expansion PCB [2] standoffs.
Connect P1 on the expansion PCB to P36 on the back of the Maincon PCB [1]. Make sure that you tighten the expansion PCB standoffs on the expansion PCB against the back of the Maincon PCB.
Attach the expansion PCB to the Maincon PCB. Use the (6) screws.
Connect the 11-pin connector [1] of the Fourth-Axis rotary scale feedback cable to P5A [2] on the expansion PCB.
Connect the 11-pin connector of the Fifth-Axis rotary scale feedback cable to P6A on the expansion PCB.
Install the combined PCB onto the 1-1/4" standoffs [3]. Be sure to connect all the cables. Install (4) standoffs onto the last PCB. Do not install the cover for the Maincon PCB at this time.
Install an electrical jumper [1] at JP2 on the second Mocon PCB.
A - If a battery [3] is installed near P1 [4] on the Maincon PCB, install the second Mocon PCB in front of the Maincon PCB.
B - If a battery PCB [5] is installed in the center of the Maincon PCB, you must install the second Mocon PCB behind the Maincon PCB.
Use the (4) standoffs to attach the second Mocon PCB to the Maincon PCB.
Connect the (2) 3/50 IDC ribbon cables [2] to the top of each PCB. Push the connectors into position until you hear a click.
Connect the Mocon PCB power cable to P15 [1] on Mocon PCB and P33 [2] on PSUP PCB.
Remove the electrical jumper from P7 [3] on the I/O PCB.
Connect cable 770 Mocon 2 Aux E-Stop to P34 [4] on the Mocon PCB and P7 on the I/O PCB. The labels at the end of the cable show the correct connectors.
A - If the machine has (1) large fan [1] under the amplifier block, the fan installation is not necessary.
B - On machines with (2) small fans, you must install a third fan [2] under the amplifier block.
  • Remove the cables from the installed fans.
  • Install the new servo fan cable to P6 on the PSUP PCB.
  • Install the other end of the servo fan cable into the (3) fans. The labels at the end of the cable show the correct connectors.
Find the (2) plugs [1] for the A-axis and B-Axis sockets. The plugs are on the side of the control cabinet. Pull the plugs out of the holes.
Install the 7-pin power connectors [2] in the sockets labeled A-AXIS POWER and B‑AXIS POWER. Then, use the (8) screws to secure the plug.
Install the 28-pin encoder connectors [3] in the sockets labeled A-AXIS ENCODER and B-AXIS ENCODER. Then, use the (8) screws to secure the plug.
The following step applies to 5th-axis drive cable P/N 36-4033D.
Find the amplifier bank locations with the A axis and B Axis labels. Then, install the amplifier for the fourth axis drive in the A axis slot and the amplifier for the fifth-axis drive in the B axis slot.
Connect the fourth-axis and fifth-axis servo cable wires to the high-voltage terminals on their respective amplifiers:
  • red to RED [1]
  • white to WHT [2]
  • black to BLK [3]
Connect jumpers [4] from both axis drives to the nearest amplifier on each side:
Connect the 16-pin connector [4] on the A-Axis encoder cable to P9 [3] on the Maincon PCB.
Connect the 10-pin connector [5] on the A-Axis current command cable to the P5 connector [6] of the Maincon PCB.
Connect the 8-pin connector [8] on the A-Axis current command cable to the amplifier [7].
Connect the 16-pin connector on the B-axis encoder cable to the correct connector on the Maincon or secondary Mocon PCB. Refer to this table:
VMC, OM-1, HS, SMM-2 without SMTC, VS
  • Maincon: P30 [1]
VF-2SS/3SS/4SS/5SS/6SS, SMM-2 with a SMTC, DT-1/2, MDC-500, EC
  • Secondary Mocon: P9 [2]
Connect the 10-pin connector on the B-axis current-command cable to the correct connector of the Maincon or secondary Mocon PCB. Refer to this table:
  • Maincon: P32 [3]
  • Secondary Mocon: P5 [4]
  •  Note: The image shows the 10-pin connector is being plugged into a stand alone Mocon where the P5 connector is horizontal. With machines with a Maincon/Mocon combination board, the P5 connector will be vertical.
Connect the 6-pin connector on the B-Axis brake cable to P31 [1] on the I/O PCB.
Connect the 8-pin connector on the B-Axis current command cable to the B‑Axis amplifier [2].
13
Install the covers for the Maincon PCB and I/O PCB.
Push [POWER ON].
Perform this procedure to enable the option Option Code Activation. Refer to Parameter Checker Program. Use menu item 7.
