Haas Bar Feeder - Motor Pulley - Installation - AD0592
Service Home How To Procedures Haas Bar Feeder - Motor Pulley - Installation - AD0592
Recently Updated Last updated: 01/27/2022
AD0592
- Jump to Section - 1. Introduction 2. Pulley Removal (3 steps) 3. Pulley Installation (1 step) Back to Top
This document and service kit applies to Haas Bar Feeders built 02/09/2015 and later:
  • 93-20-6494A - SPKT AT5-38AT5/30-2 19MM BORE BARFEED
Pulley Removal
Loosen the belt to remove the motor[A]:
Loosen the (2) screws [1] on the tensioner [2]. This lets the tension adjuster [3] move.
Loosen the tension adjustment nut [4] to remove the belt [A] tension.
Loosen the (4) screws [5] on the right clamp plate [6] to loosen the belt [A] from the right clamp plate [6].
With the belt loose, remove the motor from the bar feeder.
To remove the sweat fit pulley use a torch and evenly heat the outer diameter of the pulley.
As the pulley is heated up, pull on the pulley until it slips free.
Tips & Tricks: Place the motor with the motor shaft facing down and the pulley free to fall down from the shaft once heated.
Note: Do not pry or cause damage to the motor shaft when removing.
Pulley Installation
Install the key to the motor shaft.
Install the pulley onto the motor shaft until it stops.
Install the set screws and torque to 7 ft-lbs.
Follow the Haas Bar Feeder - Drive Belt - Replacement procedure to tighten the belt.
